Pulsar XTC ASIO - STOOOPID ?
Scotty
Ok, what happens to the ULL speed if you add an pulsar XTC to to pulsar I system? WHen you add a pulsar II to the a pulsar 1 card you can do lower than 13ms at 44.1 mhz . Will dropping in an XTC do the same? I know that the xtc has no IO but does it have the faster clock?
DSP ADD!CT
- astroman
regarding latency any 2nd generation card will do 'before' a Pulsar One and give you the lower ULLI values, but there is a certain degree in IO performance.
That was the answer I got from CWA tech support a couple of years ago on exactly the same question.
Yet this setup doesn't seem to work with all mobos (or all cards ?), as recent threads under 'problem solving' show.
