Latency issues
Rogurt
Latency issues
Post by Rogurt »
Hi all
I had sooooome out time now from my beloved pulsar sys. So right now I blow off the dust and set things up for recording sessions. Now, I am quite sure that using Pulsar 1 with 2 Pulsar2 Cards give me the low latency possibilities. But I cant go any lower than 13ms. I made quite sure that I use the hardware I/O devices of a Pulsar2 Card (also tested it in project with nothing than Pulsar2 Audio in and out dev).
Could it be something with the arrangement of the cards on the mobo? I edited the cset.ini to change the order of apperance of the cards so that my custom I/O devices would fit like on the old computer...
Cheers, Rogurt
yes, you're on the right track - just modify what you edited another couple of times (the # of possibilities is rather limited) until the 4 DSP gets off the top position ;)
Rogurt
Post by Rogurt »
thnx
