tried out some experiments with the tempo delay loop trick
- 2 loop chanels ( left and right audio )
- each chanel with a filter and insert effect
mod2+mod3 ( noice gade ) + flexor ( but just for the note pad )
demos ... first seconds with bypass ..to see the difference ..nothing special
note:
be carfule on the 6 db gain after mod insert .. this signal will be releoopd .. so if the gain is to high the audio signal swing itsel up ( aufschaukeln ) but the gain is needed if the filter was set to a low frequency
question:
how can i post pictures ... jpg as attachment wont work ?
effect loop with filteer and insert
- Dub Station Dual Chanel.rar
- mod2+mod3+[flexor]
- (427.88 KiB) Downloaded 532 times
