scope boards in open synth neko
kensuguro
Post by kensuguro »
I remember reading a thread about this a while back.. couldn't find it. Anyway, has anyone tried it? Gave it some thought? Is it a realistic solution?
They use (or used to use) an m-audio 1010LT by default--about the size of a Pulsar1 with a bunch of RCA's hanging off. I think the focusrite stuff is an option too but since that's firewire it doesn't really answer internal clearance issues. The other potential issue (aside from internal clearances) would be their choice of motherboards. I seem to recall the initial AMD based setup used a less than stellar chipset, but I believe they even have an intel based version now (?).
dobermate
Post by dobermate »
Hi guys,
Just wanted you to know that I got it up and running smoothly at the moment! It's been rock solid since a detailed surgery, removing unused boards (incl Delta 1010) and moving the others around, then formatting and tweaking settings...
2 months and counting now...:)
A lot of work 4 a large reward no doubt.
dobermate
Post by dobermate »
Absolutely! Jimmy, I figure this setup should be quite fitting for your live performances...it really is a great system as long as it works.
And it's built like a tank!
irrelevance
Post by irrelevance »
Great to hear you got it working. I was thinking of a similar setup not so long ago.
