Any suggestions? looks like i will have to try and sell my beloved pulsar cards and go with something else
PCI-e makes upgrading motherboard a problem
summer
got tired of my p4 and started looking around for some nice upgrades. Found the ram, gfx card, and cpu... all the motherboards that have gotten good reviews and that I would prefer are PCIe only...
Bifop
You can try the Asrock ConRoe865PE
http://www.asrock.com/mb/overview.asp?M ... oe865PE&s=
I'm lurking this Mobo for a cheap Core 2 Duo upgrade later this year. Lots of UAD-1 and Cubase users are already happy with it. If the PCI bandwidth is ok for the Scope's hungry devices (STWP100 comes to mind), it could be the perfect solution for all of us....
http://www.chrismilne.com/uadforums/vie ... php?t=5813
http://forum.cubase.net/phpbb2/viewtopic.php?t=60080
summer
hm... yes... the problem with the asrock is it's pci only
how about this one?
http://www.gigabyte.com.tw/Products/Mot ... A-965P-DQ6
1. 2 x PCI Express X16 slot(x16, x4)
2. 3 x PCI Express X1 slots
3. 2 x PCI slots
perfect for me since i have two creamware cards. also it's recommended for dual core overclocking.
any thoughts on this?
how about this one?
3. 2 x PCI slots
- garyb
- Moderator
overclocking? on your DAW?
well, if that's how you want to play. i prefer stability to leave the machine running for days without closing programs and being able to work as i please, without having to save or risk a crash.....
i'm sure you're competent enough to handle the technical issues though, so if you want to do it, why not? gigabyte is a quality product. the Intel is better imo. there's a reason they're in new macs. chipset, cpu and motherboard all from the same source, no compatability problems, everything just works....
Bifop
- hesnotthemessiah
I would be very interested to see how you get on with the Asrock. Specs says "supporting Quad Core Kentsfield processors". drool, droolBifop wrote:You can try the Asrock ConRoe865PE
Music Manic
- kylie
- Rank-o-phile
since I was interested, too, what is different, I checked the intel site again. the RY (precisely: DG965RY) has onboard graphics, while the LT (DP965LT) hasn't, which surely is the reason for the lower price. imho the major difference is the chipset itself (G965 vs. P965), which seem to differ mainly in the point of graphics core integration.garyb wrote:functionally they are the same. the ry has on board sound(you'll disable this), the lt is cheaper. i'd get whichever is available.
onboard audio is listet for both, btw.
you can use additional graphics on the RY, too, since it has, like the LT, a PEG slot.
http://www.intel.com/products/motherboa ... /index.htm
-greetings, markus-
- kylie
- Rank-o-phile
this is a clear proof you're not an intel salesman (as you were suspected to begaryb wrote:thanks. please excuse me. onboard graphics not sound.....
the layout looks very similar. 3 conventional PCI, 3 PCI-E and a PEG. so there should be enough room for extensions. well, they're worth a thought...
I'd prefer the LT, since the internal graphics of the G965 uses portions of the main memory.
-greetings, markus-
- kylie
- Rank-o-phile
