hello
I'm planning to buy a RME Fireface 800 to expand my Analog IO converters . I have a Pulsar 2 Z-link and a A16 ultra. The questions are : how can I connect the the Fireface ? Via Adat to the Pulsar ? Should I use a BNC cable for the digital synch between the A16 and the FF to use both the converters togheter ? Can I use it as main clock if I connect it via ADAT ?
The more infos you can give me the better is, it is appreciated
thanks
Fireface 800 connected to a Pulsar
claudioD
- valis
ADAT sync should work fine in most cases. In my previous studio I had to use a rather lengthy optical cable run from my Scope to my Hammerfall Multiface and so I would see occasional errors, bnc solved that. I've seen no actual data errors since, but for 6 feet or less (2 meters?) I can't imagine you having a problem with ADAT alone.
claudioD
manfriday
- garyb
- Moderator
- astroman
oops, if I may hi-jack...
do you still have an old A16 (somewhere) around ?
if so, could you run it's BNC sync against your studio clock ? i.e. let the A16 provide the signal and tell if there's a difference noticeable or not ?
I recently found a passage in the old manual that the A16 was supposed to act as a studio clock and had dedicated circuitry for this purpose - of course it's somewhat inferior as it's chaining from a single source only, and not star-connecting, but anyway...
