Moderators: valis , garyb
dubcotics
Posts: 253 Joined: Tue Sep 09, 2003 4:00 pm
Post
by dubcotics » Thu Jan 04, 2007 12:01 pm
hi,
I'm experience noise after recording with WaveLab 5, tho it does not happen with Cubase sx, I think it has nothing to do with the hyperthread thing, as I'm on Core duo 2, any help would be greatfull,
regards,
didier,
Posts: 23395 Joined: Sun Apr 15, 2001 4:00 pm
Post
by garyb » Thu Jan 04, 2007 5:23 pm
you may need to change wavelab priority to "above normal". it may also help to change scope to "below normal".(cntrl/alt/del)
dubcotics
Post
by dubcotics » Sat Jan 06, 2007 6:05 am
hi garyb,
thanks for your reply, but where do I find priority option within wavelab 5?
thanks in advance for your feed back,
regards,
didier,
pd: sorry for my ignorance regarding that matter,
Post
by garyb » Sat Jan 06, 2007 10:41 am
cntrl/alt/del, middle tab, right click.
dubcotics
Post
by dubcotics » Tue Jan 09, 2007 7:30 am
hi garyb,
I've tried that, there's a dialog that appears when Windows is f**ked up,
I think I'm not being understood here, it does not compute mate,
regards and cheers anyway,
didier,
Posts: 8456 Joined: Fri Feb 08, 2002 4:00 pm
Post
by astroman » Tue Jan 09, 2007 11:30 am
he meant that when you've invoked the task manager, select the tab that lists the active processes, select Wavelab.exe, right click and set the priority
cheers, tom
Post
by garyb » Tue Jan 09, 2007 4:21 pm
thanks!
