The ECC83 Tube Filter is a stereo insert effect which consists of a multi-mode filter with ECC83 tube simulation input & output stages. The tube stages feature drive controls which at higher settings, produce extreme tube saturation effects. Filter type (LP,BP,HP) is selected via the 2 digit led display.
[edit]
latest beta version (v0.2). Module now assigned to load on 1 dsp & phase alignment has been re-tested after an issue was reported. Cheers!!
[/edit]
[edit]
latest beta version (v0.3). insert slot no longer set to load on the same dsp as the device.
[/edit]
[edit]
latest beta version (v0.4).
-Added gain reduction circuit as requested by musurgio. It's represented by a new gain switch, which at low (default) implements the gain reduction & at high, is as it was (extreme tube drive)
- Calibrated input & output stages to +/- 12dB
[/edit]
[edit]
latest beta version (v0.5).
-Download now contains mono & stereo versions of the device.
-Added filter bypass switch & tweeked filter response.
-Added pre-filter insert.
[/edit]
Update !!
latest public beta version (v0.7)
-added presets ('Tube Filter.pre' file included in download)
Have fun
regards,
Shroomz
 Looks simple enough I can't break much.
