dev to vst dll converter
the19thbear
Post by the19thbear »
i spend some time converting dev´s to dll´s to use in my xtc setup. I would LOVE a small windows program that could convert the a device to a vst dll., all it has to do is rename it!
i´m no programmer otherwise i would do this myself!
thanks
and merry christmas!
hifiboom
Post by hifiboom »
just a tool that renames a dev into dll?
or one that renames the sandard XTC vst dll (20KB size) into the devices name + ".dll" ?
the19thbear
you are right, the latter! can it be done?
Shroomz~>
Post by Shroomz~> »
What you need is a general file manager which is able to rename files & copy them to a new location which you specify (like your XTC folder), but it would need to be able to do this automatically (using pre-set instructions) by just dragging files onto it. If it wasn't automatically renaming & copying straight to your desired location I don't see the point, as you won't save time by opening an application every time you want to rename & copy a file.
hifiboom
Post by hifiboom »
Okay I did a very small tool for you! because its XMAS! hehe
Copy the two files into the folder where all the DEVs are inside.....
run it and click convert
The tool will make the XTC dlls in this folder.
You still have to manually copy the dlls into dedicaded VST folders....
best regards.... :wink:
XTC_converter.rar
XTC converter.....
(6.92 KiB) Downloaded 384 times
the19thbear
THANK YOU!!!!! very cool!!
thanks!.. worth to put in the "device" forum?... i know its not really a device...
thanks again!
the19thbear
thank you!!! woth a "device" post? i know its not a real scope device.. but..
hifiboom
Post by hifiboom »
do it if you want,
its not that spectecular stuff... :lol:
mediamalte
Post by mediamalte »
Thank you - this is a real perfect Tool - small and very usefull :D
Scope Home + Pulsar 1/ AMD Opteron 2,4 Ghz/ 3 Gig Ram/ Nvidia 7800GT/ a lot of HD Space :-) and Windows 7
