Modular folders
arela
Modular folders
Post by arela »
hi
With modular 2 and 3 i was lucky to get this to work, but not shure with Flexor:
I made a folder called Modular, in witch i put all modular 2 and 3 folders into.
(saves space on menu)
Do you think this wil be a problem with Flexor added?
(i have done it, but not fully tested)
This is "as should be"
Modular p1.GIF (3.78 KiB) Viewed 3365 times
This is how i want it - it works, but not shure if it works with all patches
Modular p2.GIF (7.34 KiB) Viewed 3365 times
As long as you're only using it to access prebuilt modular patches that use Flexor (like the flexor 'preset' patches & VIP patches for example).
It's the .mdl and dsp files etc that must be properly installed into their respective Modular2 folders (which is taken care of by following the flexor install procedure).
arela
Post by arela »
ok valis - i'll give it a try (no prob so far, but....)
Since its more than 3 years since i was playing with the modular, i'll guess i have som learning in hand. Hope there is some free space in my RAM :D .
arela
Post by arela »
Back to start
Could not open some patches, so i found it was no idea to continue this experiment :cry:
irrelevance
Post by irrelevance »
Did you not get the search dialog? You should just be able to restore the patches with your updated location.
arela
Post by arela »
You might be right here irrelevance, but the trouble is i don't know what i have and misses.
I just bought FleXor and BlackBox, but there might be other devices some of these patches needs.
So i need to go through all patches first, then i will try again.
There is no trouble with mod2 and mod3 patches. Also a lot of the other patches with Flexor and Blackbox was ok, but some failed, did not open at all.
No dialog box on those.
Herr Voigt
Post by Herr Voigt »
Is there any trouble with Mod 1? I wouldn't like to go without it.
arela
Post by arela »
Mod 1? is it incoperated to Mod2? I guessed there must have been a no. 1, but i can't find i have it.
