i have pulsar i card and i work with behringer analog mixer , but now i nave yamaha 01 v digital with 8 - my aes/ebu card with 25-pin conector
-where can i find optical cable to link my pulsar and yamaha 01 v ?
-that is pulsar's product or yamaha's ?
							please somebody help me (optical cable)
JOVICA KARALI
						Re: please somebody help me (optical cable)
so you don't have an adat card in your yamaha? then there's no way connecting the pulsar via adat to your aes/ebu input, since it's electrical, not optical (and a different protocol anyway).karali wrote:i have pulsar i card and i work with behringer analog mixer , but now i nave yamaha 01 v digital with 8 - my aes/ebu card with 25-pin conector
1) get yourself an adat module for your mixer.-where can i find optical cable to link my pulsar and yamaha 01 v ?
2) ask your local electronic shop for an optical toslink/toslink cable. I could imagine you could get one from yamaha if you desire, but at a higher price. I don't remember cw having offered an optical cable as accessory...
-greetings, markus-
Re: to markus
if you have the pro plate/layout, yes. the classic one has unbalanced analog i/o instead of balanced, and no aes/ebu.karali wrote:i think that aes/ebu card in yamaha mixer is right card to link with pulsar
there are cables called digisnake with db25 to 4 xlr male and 4 xlr female. they are available at several online stores.
but you could route only 2 channels to/from scope, not 8. and you can't use an optical cable. this would mean adat (8 channels, yes), and thus an adat i/o option for your mixer.
-greetings, markus-
There's no way you'll be able to link your pulsar and your 01v without the adat card.
I used to have a 01v with the adat card (wich is called MY8AT) to hook it up with my pulsar. This card has 2 toslink conectors (optical) while the AES/EBU one (while still digital) is electriclal.
This is what you should get:
Martín
Martín
one could also use this one:
http://www.mutec-net.de/e_pro_fcmaa.htm
it's about 450,- EUR from what I read at thomann.
-greetings, markus-
-greetings, markus-
thanks to all of you
now i'm shure that i must get adat card to conect pulsar , and put mu aes/ebu card in tresh........and stil mixing in cubase or pulsar mixer.
btw ohrid is still beautiful....
JOVICA KARALI
