PulsarII + Luna I/O + Scoope 3.1C on Win XP?
midifile
Post by midifile »
Hi all,
I have the PulsarII + Luna I/O + Scoope 3.1C running on
an old pc with windows 98se, because i have been a
great fan of tripleDAT. But it seemes the development
of this product are not happening at all :-)
So i have decided to go and buy me a bigger and better
PC with a lot of ram and windows XP.
Then im gonna buy Cubase 4 Studio.
However my question is will my equipment:
PulsarII + Luna I/O + Scoope 3.1C work with
Cubase 4 Stuido on Windows XP?
On the PulsarII package it says: "PC, 300 Mhz, 64 Mb Ram, Windows 95/98"
Thanks for all Input!
Audiographe
Post by Audiographe »
Motherboard = Asus (& if possible "Deluxe" version, P4P(or C) 800-Dlx, P5B-Dlx)
Power supply = if possible Antec (1 more Fan in front face).
Ram = Kingston (1024 mini)
midifile
Post by midifile »
Thanks,
But will the audio card Pulsar II run on windows XP?
I was looking at this PC setup:
Intel Chipsset
Dual Core
2 Gb Ram
SATA Harddisc
opdate SFP to 4.5, check the CWA site, you get a lot more for a few bucks more than back in those days (M'nM or S'nS pack) :-)
There's no problem to run on XP, they even say even Vista support is at the zenith, tho Creamware said nothing about it.
The only hardware barrier is the new type of PCI-e, so check out to buy a board with 'old' PCI slots :-)
midifile
Post by midifile »
The only hardware barrier is PCI-e, so check out to buy a board with 'old' PCI slots
OK, Thanks - that was really important to know!
So the old PCI slots are called what? "PCI-e"
Cool.
no, the new ones are called PCI-e, and we also had a few PCI-x, on mac at least, but that path is abandonned already.
So PCI you must have, the advised boards from above undoubtly have them :-)
(I don't know actually, I'm on mac).
Audiographe
midifile
Post by midifile »
Hi again,
Does any one know if theese two setups will work with the Pulsar II PCI-card:
Config #1:
Intel Pentium Dual Core 3.0GHz 4MB S-775
ASUS P5LD2/SE Intel 945P S-775
Config #2:
Intel Core 2 Duo E6400 2.13 Ghz /1066 Mhz
LGA775 Socket / Intel E945P Express
Celeron D, Pentium D
Socket 775 / PCI-32 / PCI-Express
Thanks!
i'd go for the core duo, it's a better processor.
the 945 chipset should be good, but i'd go for the 965. the intel d965ryck, it's about $125-135.
