There seems to be some bugs in the modular. Can someone confirm my problems:
(1) somethimes I cannot link cable into holes where they should plug-in fine. If I start with a new patch, the cable plugs in fine. Later not is there any workaround?
(2) and some crashes when browsing and loading some patches back into scope - not exactly reproduceable...
(3) some modules sometimes don`t work the way I want them to do ( envelopes modulating filters sometimes seem to have no influence on the filter) but this could be my fault
Is this normal?
I' ve searched this forum a little bit and many claim its the mod III shell. I really must say I prefer modIII preset handling over the modII shell.
normal bugs?
irrelevance
When this happens, right-click the module you're trying to connect to and select disconnected. This seems to reset the module i/o.(1) somethimes I cannot link cable into holes where they should plug-in fine. If I start with a new patch, the cable plugs in fine. Later not is there any workaround?
I used to think Mod!!! was certainly less stable, or at least more likely to crash my system than Mod!! but now I'm not sure2) and some crashes when browsing and loading some patches back into scope - not exactly reproduceable...
...or so it seems at least
Do you have Flexor? If so connect a val moniter to see whats going on or even connect to audio outputs and capture in an audio editor.(3) some modules sometimes don`t work the way I want them to do ( envelopes modulating filters sometimes seem to have no influence on the filter) but this could be my fault
ah interesting...
thanks faxi...
good to know.
I think I didn`t copy paste the module when I had the problem.
It was the simple flexor hyper smooth envelope connected to the modulation inputs of the a butter filter, where I moved the knobs for modulation.
The gate of the ENV was connected to CV midi in,
at the end no effect was audible, when I moved attack, decay, sustain on envelope etc...
So I inserted the CW one and had a result.
thanks faxi...
good to know.
ah just found this! could be thesame problem as I have:
I`m sure I used the MVC B gating the FilterEnvelope...
http://www.planetz.com/phpBB2/viewtopic ... f2f621500e
To make Flexor env's work you should connect esync-out to gate-out (cross connection at the MVC). Sometimes i had to change midi channel of the modular patch (for example if it is 1 then i put it 2 and then 1 again) in order to make them work (that implies to several situations where something has changed in the MVC).
ey, now I checked this and yes with MVC A the Flexor ENVs seem to work like a sharm.
and irrelevances trick with disconnecting a module seems to be a nice workaround for problems with cables.
So 2 of my 3 problems are solved...
the load bug isn`t that bad, I think I can live with that.
maybe next SFP version ( 5.0 with vista drivers
and the fully assign- and designable modular MUI for synth creations.... YEEEEEEEEEES !
thanks all!
thanks all!
