Delay with inserts
Liquid Len
Delay with inserts
I would like a delay that I can insert an effect into the feedback loop (so every time it repeats, more effect is added). I didn't see any way to do that with the stock delay effects, but might have missed something.
- Mr Arkadin
- spacef
i just realized there was nothing about inserts in the echo manual (only in the tricks section). it is corrected now (echo manual updated)
Wolf's device is called Matrix Delay
see you
see you
Liquid Len
Yup, ModIII did it, I just learned about using the xmod/feedback connector (to allow you to feed a delay into itself). Though I've been checking out SpaceF's echo, very nice it is.Mr Arkadin wrote:i think space f's ECHO series are the only delays with inserts. You could probably build something in ModIII if you know what you're doing (i certainly don't).
