What is the best backup software?
Drive image failed for me early on and I want to replace it. What should I get? Another problem is testing because of the DRM in NI products and now I suspect in Windows too. I can't just restore a drive anymore. I have to jump through all these hoops and I hate it.
http://www.terabyteunlimited.com/imagew.html
They have both dos and windows version of the software. Dos version looks and feels a bit like northon ghost. You can make byte to byte exact copy of your hd. There is also very handy verify feature to make sure your image is 100% correct.
I agree with Acronis True image for a HD system backup.
And for your audio files Viceversa Pro( http://www.tgrmn.com/ ). You can create a shortcut for create a backup process of diferent files and folders to a diferent hard disk destination.
It is very usefull for me.
Astral Fridge Magnet
I have always used Ghost but have now tried Trueimage. What bothers me with Trueimage is what happens if the computer doesn't start at all?Astral Fridge Magnet wrote:You can't beat Acronis True Image. It is as said earlier, "simply the best." Though I have to say I prefer version 8 to version 9.
By the way, I used to use Norton Ghost a couple of years ago, but I much prefer Acronis.
With Ghost I use a startup diskette, then loading the image from several splitted DVD-RW discs, so in 40min I'm back with all setup again.
As I run trueimage now I must have Windows up-and-running to be able to restore, but you can maybe create some kind of start diskettes....
from the acronis manual:
roman
cheerzWith Rescue Media Builder you can create bootable rescue disks or their ISO images. You might not need this tool if you purchased a boxed product that contains a bootable CD. Installing the Rescue Media Builder will allow you to create bootable media or its ISO image at any time running Rescue Media Builder on its own.
roman
