hard disk error
firubbi
hard disk error
Post by firubbi »
I have 2 sata HD. Lot of time the master HD(80gb) got failure and a blue screen came. If I restart problem remains but if I shutdown and start after some time problem went off. But after an hour it happen again.
This is my 2nd pc connected with pulsar2(ADAT_port) and I run gigasampler and few vsti. It’s a 3.2 duel core P4 and Asus P5WD2 motherboard +2gb ddr2 ram.
can you tell solution plz.
thanks
firubbi
Post by firubbi »
thanks stardust
how to do no 3? i mean how i can find if the mobo is ok or not?
it could be a bad cable as well. basically, you have to use deduction and reason. if you determine that it's not the drive and you check/swap the cable and it's not fine, it's the motherboard. i'd bet on the cable, then the drive. the motherboard is the last suspect.
back up crucial data first is good advice.
firubbi
Post by firubbi »
thanks. i'll check both and come up again.
arela
Post by arela »
i had this issue, and after i excanged S_ATA cable everything was ok.
