nearly all devices are updated now !
These updates address mainly the surfaces and some small bugfixes, but also introduce some significant new features and new devices.
Despite the work put in all updates are free for exisiting customers !
Regarding spEQtrum: There was a wish to put the controls in a separate window. Beside one person everyone responded with no need for that (via mail), so I decided to put my ressources in other working areas (sorry, erminardi).
As SpEQtrum is now one of the most flexible EQs available today, I decided to raise its price for 10 Eur, but not before November, so hurry up to get the update for free.
Below is a list about what has changed for all devices.
Changes
spEQtrum v1.5 :
- surface redesign
- gain coupling for more emulation possibilities
- new behaviour and usage of frequency coupling
- selected band is now highlighted
- deactivated bands don't vanish anymore, but are dimmed
- some smaller fixes not worth to mention (in reality I forgot them)
- some internal changes, which makes it easier to supply future updates
- manual updated
AnalyzerPack v1.2 :
new devices added:
- bridge8
-> peak & rms level meter bridge for 8 in/outs)
- 2vu / 8vu
-> small level meter with LEDs to see levels in the routing window, helps a lot for having a fast overview
fixes / changes:
- all device titles can now be renamed by simply clicking on the title
- Analyzer B/C: surface positions now remembered, when used as insert
- surface position now remembered in screensets
- manual updated
MidiToolBox v1.4 :
new stuff :
Audio2Note (device)
This one is different to the free version as it has more options and therefor can achieve better and more consistent results.
SoftTakeOver (modular module)
fixes / changes:
- LFO2Control / MultiControl: dsp saving routines added
- devices: surface position now remembered in screensets
- modular modules: poly/mono switch removed (it made no sense anyway)
- modular modules: internal changes to allow sharing of modular patches
- manual updated
MatrixDelay/MatrixInsert v1.1 :
- surface redesign
- MatrixDelay: fx-pre-delay setting now routes wet signal through the fx section
- MatrixInsert: added in/out peak vu and VU LEDs after each insert
LoopMangler v1.2 :
- added separate outputs for each loop line
LochNess v1.1 :
- added eq curve to see result of dynamic eq
- eq curve can be hidden
have fun!
Wolfgang
http://www.worldless.com/sfp/
