what am i doing wrong?
srigi001
Post by srigi001 »
so here's the thing
I routed a stereo channel in Nuendo 3 via stereo output bus back to pulsar, inserted on that channel a 4 pole filter, assigned the frequency knob to a knob on my controller (CC 91 to be exact)...up to here everythings allright.
Now, i open a midi channel in Nuendo and record a live automation ( i see the data being written )and hear the changes but when i playback the segment in order to listen to what i've done no changes are being heard, the knob doesnt move!
in the pulsar project window i got my Pulsar midi source routed to my sequencer midi destination and also to the STM 1632 midi in (otherwise i wouldnt have been able to assign that knob obviously) and the sequencer midi source to the pulsar midi destination
any help would be mush appreciated
thanks
the sequencer midi source should feed the mixer's midi input. you can monitor midi into the mixer realtime through nuendo if the chosen midi track is record enabled.
arela
Post by arela »
You can use a midi merger
CWcard midi>
> Midi merger2 > mixer
Nuendo midi >
djmicron
Post by djmicron »
the sequencer midi source must be connected to the device that you want to control with midi automation.
When you are working with sequencers, the best thing is to use sequencer mid sources and to control the devices from midi tracks instead of using a direct link from the pulsar midi in and the scope device.
srigi001
Post by srigi001 »
thanks guys it worked
i hooked up the Sequencer midi source 2 to the midi in of the STM and voila!
cheers
