Zero Problem Users
bigdave
Post by bigdave »
Well guys, if you are among these kind of mutants who never had some f*****g problems with their setup, i think it could be great to tell us what is your secret ...
Wich Mobo / CPU / RAM ?
Video Card ?
Hard Drives ?
And so on ...
Thanx.
mac G4, Corsair RAM, that's all I (wanne) know :grin:
Shroomz~>
Post by Shroomz~> »
It's your NF4 chipset that's at fault!
Asus A7N8X deluxe (NF2)
... one of the best PCI bandwidth performances on the platform!!!!!!!!!
<font size=-1>[ This Message was edited by: Shroomz on 2006-10-16 17:35 ]</font>
symbiote
Post by symbiote »
amd64 3000+, gigabyte k8ns (nf3), corsair ram
there have been a number of no problem setups for me. almost all are with intel processor/chipsets.
arela
Post by arela »
a device like a pc will always cause some unexpected reactions :smile:
erminardi
Post by erminardi »
I've a NF4 chipset and I don't have any problem.
My secret??? Maybe because I've PC since 1992... DOS, Win3.1, Win95, Win98, WinMe, Win2k, Win XP... and MAC since 1996. I'm very very expert now.
PCI & IRQ, etc. have no more mystery to me :grin:
Shroomz~>
Post by Shroomz~> »
:grin:
In truth, Scope can crash because of a mistake/fault/bug in one of the applications (a 3rd party beta for example) ... not just because of a system spec!!
Counterparts
Post by Counterparts »
Never had many problems, just one issue with cracks & pops in Cubase quite some time ago, which I solved á la here:
http://www.planetz.com/forums/viewtopic ... 96&forum=3
(Basically, uncheck the 'lower latency' box in the Advanced settings dialog under Device Setup...)
I use an ASUS MOBO, a PIV 2.6 GHz CPU, 1.5GB RAM and an AGP Graphics card running Windows 2000 SP4.
The only performace-based 'mod' I've made is to install Windows 2000 as a 'Standard PC', not 'ACPI PC'. This is only necessary for Windows 2000 w/ older-ish MOBOs though; if you're running XP on a modern MOBO, it should be installed with ACPI (and APIC) enabled. Beyond that, I've not tried to apply any tweaks to improve the audio streaming.
Software-wise, I'm still on Scope 3.1c and using Cubase SL 2.
Presumably you've made this posting because you're having problems..?
HTH
Royston
mr drummer
Post by mr drummer »
asrock 848p - P4 3.00 ghz - 2 gig kingston -scope 4.5 running on acpi and (amd xp2500-msi-kt7 - 1gig twinmos for fx teleport server)
working with continously decreasing number of problems (i can say nearly none now) since i found planet-z and study the forums :smile:
i think it's much more about knowing the key basics which they do not tell you elsewhere...(a big one for planet-z community here :smile: )
<font size=-1>[ This Message was edited by: mr drummer on 2006-10-17 07:41 ]</font>
fidox
Post by fidox »
Abit IC7 (875 chipset)
P4 2.8HT (HT - disable)
1GB RAM (4 x 256)
radeon 9600PRO
120GB WD IDE
4.5 SFP
2 x Pulsar XTC + 1 x Luna II (15dsp)
WinXP - Standard PC
:wink:
Herr Voigt
Post by Herr Voigt »
ASUS P5AD2-E Premium
Intel Prescott 3,2 GHz, HT off, ACPI enabled
2 GB RAM
Matrox P 650
Samsung Spinpoint 200 + 250 GB SATA
Scope Pro with 4.5
Win XP Home
Works fine after some tweaks in Cubase SL 3.1.
<font size=-1>[ This Message was edited by: Herr Voigt on 2006-10-17 16:07 ]</font>
H-Rave
Post by H-Rave »
ASUS A7NX-X
ATHLON 2500
1G Memory
80GB Hard Drive Western Digital
Windows XP Pro SP1
Windows XP Home SP2(Just for music)
ACPI Mode
Cubase,Soundforge Kontakt
2 Pulsar 2 and 1 Luna 2
No Problems here.
Mmmmm......Nice.
<font size=-1>[ This Message was edited by: H-Rave on 2006-10-19 09:38 ]</font>
soul-synthesis
Post by soul-synthesis »
cpu: amd64 3200+
mobo: msi k8n neo platnium (nvidia nforce3 250gb)
ram: corsair twinx 1024mb (2-2-2-5)
video: nvidia 6800gt
power supply: antec trupower 430w
hdd: 1x seagate barracuda 120gb IDE, 1x seagate 160gb SATA, 2x western digital 180gb
CW: 3x Pulsar 2 (1x plus, 2x classic) + sync plate, 1x noah ex, ext sync via Swissonic A/D unit.
OS: Win XP (custom unattended install with nlite, xplite and other tweaks)
S/W: SFP 4.5 & Nuendo 3
Rock solid setup! I'm really happy with it. No problems or crashes yet. Masterverb test = 20.
jimmypage
Post by jimmypage »
my setp rock solid stable
P4 2.8 RDRAM(rambus) NO HT sigh :-?
1024 MB PC800 next upgrade to PC1066
MB INTEL D850EMV2 RAMBUS
Geforce 6600 very best performance video
3x scope card
2 ATA 100 HD barracuda 80 GB
midiman radium keystation
rokit5 speaker
windows home ACPI enable rock solid stable :P
MASTERVER TEST 15
A lot of plug specially synth 8)
I have this PC from 4 year ago neve problem I happy like one session with my girl :-P :wink:
ARCADIOS
Post by ARCADIOS »
no problems with:
1. asus p4c800e prescott 3.0, standard pc. perfect!!!
2. ic7g prescot 3.0, standard pc. perfect!!!
current system
mobo: gigabyte ga965p conroe6600. great system but needs more research to make it stable, unless i setup on standard pc.
please creamware!!!!!!!!!!!!!!!!!
give new drivers for multi processors.
:D :) :( :o :-? 8) :lol: :x :P :oops: :cry: :evil: :roll: :wink:
Intel D865PERL w/ 3.0GHz Northwood
Kingston ECC DDR PC3200
Matrox G450 32 MB DDR 8x AGP
Raptor HDD's
Scope Professional TypeII, Project Type II
Intel DP965LT w/ Conroe E6400
OCZ DDR II PC6400
eVGA GeForce 6800 PCI-e 128MB
Raptor HDD's
Scope Professional Type II, Project Type II
Intel DP965LT w/ Conroe E6700
OCZ DDR II PC8500
Raptor HDD's
Scope Professional SRB Type I, Scope Project Type II
Intel D875PBZ w/ 3.4EE Northwood
Samsung PC3200
Matrox G550
Raptor HDD's
Scope Professional SRB Type I, Project Type II
The first DAW was my first one with Gigastudio 3 Orchestra and SFP 4.5
The second DAW will be my FOH / Monitor mixer DAW w/ extra synths
These are both operational and extrenely stable, 100% record at all gigs to date.
The third DAW will run Cubase 4, SFP. and the new multuthreaded Gigastudio in it's VST form, and extra synths.
The fourth DAW will be a drum submixer w/ Gigastudio 3 Orchestra, and SFP, plus extra synths.
The last two DAW's will be up and running after I purchase another Type II card, and Cubase 4. I'm only short on Cubase and another card to make this a reality. But all of these parts have been swapped at times, and are stable. Plus the Supermicro P4SCT+II in my old DP DAW worked flawlessley.
All Of These Dogs Will Hunt,
psionic
Post by psionic »
I have:
P2 MMX 133 MHz
Luna2
Cirrus Logic 5446 - 2 MB RAM
HDD IDE 800MB
64 MB SDRam
32 x CDROM Teac
Midi filter
Everything works fine...
Software:
Win 98 - Standard PC ( although I must pull the cable from wall to turn of PC, it doesn't boter me much... )
Windows with no graphical interface, only CLI - it slows down the PCI transfer.
SFP 4.5
Cubase SX 0.1b - ( will get 1.2 when I get more ram - I heard it is ram-demanding )
Sound Forge 1.0a - ( I wanted 2.1beta, but who needs all the fancy stuff, they are slowing my PC )
That's it...
Didn't I mention that I am working on a new Madonna's album ? I have some problems LOADING BFD DRUMS PLUGIN IN RAM and USING MORE THAN 2 CHANNELS SIMULTANEOUSLY, but, hey, you can't get it all... :D
dxmat
Post by dxmat »
mobo ASUS P4PE
cpu P4 2.6 Ghz
1 Mb RAM
HD x2 Maxtor 9 250 Mb
ATI Radeon 9600 Pro
Pulsar II + Luna II
WinXP Pro SP2
very stable!
Audiographe
Post by Audiographe »
Pulsar I + Pulsar II + SRB I (14DSP)
ASUS P4 C800-E-DLX
Antec alimentation (important)
Pentium4 3.0G (Important > Very Big CPU FAN)
RAM 2048 kingston
ATI RADEON 9200
Asus DVD Drive
IBM+MAXTOR+SEAGATE
Asus Screen (Beautiful, Rhaaaaaaaaaaaa :D
Ps : No problem
