<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/dev ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: Effect<BR> _____________________________________<BR><BR> http://www.planetz.com/Pulsar/files/dev ... 6Drive.zip
I removed all old versions in the forum.
B.t.w. The packages are mainly for those who missed an update or were confused by the many devices.
K1-C- This package part 3 contains the whole dynamic & drive stuff.
evilknott & XL now can handle presets (as any other in the collection can, for which it makes sense).
Martin
P.S. Any device which holds inserts has to be renamed to *.dev when using presets on those inserts. Sorry. Corrected that for "dieknotts", but there are other devices, which could need this modification when working with presets.
<font size=-1>[ This Message was edited by: MCCYRANO on 2006-10-13 12:14 ]</font><BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/dev ... cdrive.jpg" BORDER="0">
K1-C Knotts-Scope-device-collection 1.0 Part 3 - "dynamic&dr
- Ben Walker
- kylie
- Rank-o-phile
martin,
you better try to avoid using special characters in filenames (like the ampersand sign). this breaks several browsers or download helpers, if becoming part of an url.
Edit:
it seems to break at least GetRight. mozilla alone does not show this behaviour when using "save as".
a working url for this file would be:
Edit:
wget users can escape the ampersand with a or put the whole url into ""
-greetings, markus-
In the beginning was The Word, and The Word was Content-type: text/plain
<font size=-1>[ This Message was edited by: kylie on 2006-10-12 11:48 ]</font>
Edit:
Edit:
-greetings, markus-
- kylie
- Rank-o-phile
it appeared that it mainly confused my 2 favourite tools. but whoever uses GetRight (and it is widely used) will have that problem. and, yes, since I can't even force myself to include every url in quote signs when using wget I use to run into this problem every now and then...So I leave it as it is now if your link should work for all!
sorry for the (partly) false alarm.
-greetings, markus-
