Got this error when starting Scope 4.0
tangerine
Post by tangerine »
Sometimes got this...
My setup:
Pc AMD 3000+ 2Gb Ram, Mobo Gigabyte K8NSC, Creamware Pulsar fx (6dsp)+ Scope 4.0, M-Audio Audiophile 192, Mbox + PT 7.1
<font size=-1>[ This Message was edited by: tangerine on 2006-10-08 11:45 ]</font>
arela
Post by arela »
Looks like a bad connection.
Or
Is there a ASIO conflict between your other cards?
voidar
Post by voidar »
What OS is that?
tangerine
Post by tangerine »
Arela: for bad connection you intend phisical problem connection? for the Asio is possible because I've another two card in my pc...
Voidar: Windows XP SP2
Thanks.....
P.S: I've found that my Pulsar and my Screen Card (a Nvida 5600 card) have the same IRQ... probably can be that????
<font size=-1>[ This Message was edited by: tangerine on 2006-10-09 01:16 ]</font>
He's using a custom theme/skin voidar. Stylexp or perhaps the .mysstyles hack (hopefully not WB).
tangerine
Post by tangerine »
nw uxpatcher Valis :wink: ....
voidar
Post by voidar »
Shared IRQ is not a good idea. Only Scope-hardware should share.
Are you running a "Standard PC"-setup?
tangerine
Post by tangerine »
Yes, i'm running a standard pc...
Now I've changed the pci slot, and I obtain this
It's correct no??? The Pulsar have its IRQ...
but scope now doesn't start ever!!!
Think I want to destroy the Pulsar!!!
<font size=-1>[ This Message was edited by: tangerine on 2006-10-09 12:21 ]</font>
Ah that works too =]
So, the usual round of fixes to try for your situtation would be:
Simply try reseating the card(s) and any stdm cables you may have.
Clean the gold contacts of the card (and perhaps the pci slot) with cotton swaps and 99% isoprobyl alchohol (not grain alchohol and not 70% or less).
Check the voltages of your power supply using a software utility under NORMAL pc load (boot voltages my be different). Especially when trying to start scope.
Eliminate overheating as a factor, both for the card(s) and your system components (the latter should be obvious though).
Make sure the rest of the system is functioning completely normally and it is ONLY Scope having problems. I think SiSandra might have a trial version and there are other stress-test programs on the market.
Given the error you showed above my personal opinion on the most likely problems would be the Power Supply, poor PCI slot contact (the cleaning solution) or an unfortunate hardware failure in the cards.
tangerine
Post by tangerine »
First of all: thanks for the help! you're so gentle and patient..!
So...... Now I'm working so I can't try your solution, but I remember the fact that if i disconnect the wi-fi usb pen, 2 time on 10 try Scope starts... in the other case never! So is it possible that is the power supply!
This night (here in Italy) will try!
thanks.
P.S: Sorry for my terrible English!
I would also suggest you go into your system BIOS (on boot) and disable unused devices, specifically COM & Parallel ports that you do not use.
tangerine
Post by tangerine »
I've disabilitated Serial and COM ports on BIOS.
I've tried to disconnect all the Usb peripherals I don't use or not important, but Scope starts 2-3 times ever 10 times.
The fact I've remember is that is not a fresh install of both Pulsar II & Scope but I've used it for 3-4 months and it works regularly.
Next step is to polish the contact and the PCI slot.
Disabling unused devices isn't going to fix your problem, it's just something that I recommend. I'm sorry you're having problems and I do hope you can fix it without resorting to contacting Creamware. At least if you do have to go to CW you'll have done some of the basic things they'll ask you to do. :smile:
tangerine
Post by tangerine »
Ok, I've put my Pulsar II on my old pc (an AMD 600 Mhz, 192 Mb RAM) and it seems to work very well. Now, I've to record eight tracks (a drum) in pro tools free... Anyone knows if is it possibile? I know that pt free doesn't work with ASIO. What i've to do in scope to record the signal from ADAT input of my Pulsar in PTfree?
Thanks!
