Hello!
Since I´m working with a bcf and a bcr I realized that sfp is sending all used midi-cc-values when a project is loaded!
Really cool!
But if you use several presets, only the currently selected is updated.
So I´m dreaming of the possibility to send those cc-values whenever I like... Just pressing a button or something like that...
Is it possible to create such a device in sdk?
Cheers,
Jan
Send all used cc values
- spacef
- next to nothing
- spacef
- Janni
The point is, for example, if I open a project, only the currently used preset of the bcr/bcf is updated.
If I used another preset in another project, it´s not fitting to the current one...
As I want to use it live and use mouse and "real" tweaking at the same time, I probably have to add a logic environment for that task...
Another question (probably very silly
: is it possible to create something with sdk that could let us use relative cc values?
Cheers,
Jan
Cheers,
Jan
- spacef
ok i understand, and i am not sure it is possible, because as you noticed only different values are sent - and received by bcr. so it would be more reliable to save also a bcr preset for each of those projects.
for the device about relative values, i have no idea myself. if there is a way (which not sure) it would probably be at a high dsp cost when you think in hundreds of parameters.
May be someone else would do it.
I hope it helps
<font size=-1>[ This Message was edited by: spacef on 2006-09-26 13:00 ]</font>
I hope it helps
wolf
