Using Separate Outs
If you want to have a stereo sample coming out from, say,1 & 2, you have to set also individual outs "OFF" in the Main Panel (Additional section)and assign the outputs in the Keygroups Panel in the "Add" section. There you will see the samples for the L channel and those for the R channel, if you have the "Edit All" button on (as default) the assignation you make there will affect all the keygroups for that prg.
				Nebukadneser
Ahhhhh
- the edit all function (Editing Zones) messed things up for me! I wanted the snare drum from a Bob Clarimountain kit (AKAI CD) to go to an individual out by programming at the Zone level. Coul'd not make it work as all assignment changes I made, automatically applied to all zones.
Bug, I thought - until I searched this forum and found the answer - thanks Planetz!
Neb
Neb
				Herr Voigt
