Hi!
I have some preset files, for example for Pro-12, and I would like to include them into one file. Is there a nice and easy way of doing that?
flips
Possible to combine preset files?
- at0m
Load the second list in the right-hand preset panel (you may have to drag it open a bit w the mouse from right to left), then drag over the presets to the list which you want to use as a bulk. Re-save that combined list as a file, and you're set...
flips
Kymeia
You can select more than one preset at a time by shift clicking on the top one then the bottom one - to copy over all the one's you've selected use preset/copy from one side of the split and preset/paste from the other instead of drag/drop.
Can't seem to find a way to copy over a whole bank though from one file to another - only presets.
