Zarg website
Crickstone
johnbowen
Hmmm, I just checked both addresses, and all seems fine (you can use http://www.zargmusic.com or http://www.johnbowen.com).
It must have been down for some maintanence when you tried...
Definitely still here!!
regards,
John Bowen
regards,
John Bowen
Crickstone
djmicron
it is possible that there is a problem with your internet connection provider.
Try to trace the route of zargmusic.
To do it open the command prompt (start/run/cmd) and type " tracert johnbowen.com " and the latest result should be
gs13.inmotionhosting.com and if not, contact your connection company.
If you go to http://www.anonymouse.org you can surf the web using a different proxy than the one assigned to you by your company and you should be able to navigate to zargmusic web site.
Regards
Micron
Regards
Micron
Crickstone
