Opinions on the best eq and compressor for scope
bcslaam
Post by bcslaam »
Hi
I was hoping to hear peoples opinions on the SOUND quality in particular of all available eq and compression devices for scope. Asthetics are not an issue here.
I have vinco and think its almost on par with my UAD-1 urie-ln. But i have no other hq ones.
I tried ISON demo and its top end definately sounded better than the ones in stm 4896. Bottom end also seems to behave more musically.
I'm interested in devices that can be used on many channels, not so much the overly dsp hungry ones, although i realise there will be a bit of grunt required. I run a 25 dsp system.
I know there are similar threads but I was hoping for a sorta mild shootout.
<font size=-1>[ This Message was edited by: bcslaam on 2006-09-10 04:12 ]</font>
erminardi
Post by erminardi »
Try this, I like it because it sounds very good, is not DSP eater & is free: http://dev.d-mute.com/dcomp.zip
Scope 4.5 + 2xPulsar II + 1xLunaII + 1xPulsar1 + a lot of devices = Pure Joy :smile:
<font size=-1>[ This Message was edited by: erminardi on 2006-09-10 04:44 ]</font>
MCCY
Post by MCCY »
Try my devices ;o) - especially the LC1 & MOVeq. Tong & DynaMyth sound very good too, but are a bit complicated.
<font size=-1>[ This Message was edited by: MCCYRANO on 2006-09-10 15:12 ]</font>
Eric Dahlberg
Post by Eric Dahlberg »
Though the VinCo & 1176LN look the same, the VinCo sounds more like the SSL & DBX VCA-type compressors. I find it to be more flexible than the 1176LN is. Add the UAD-1 LA2A to your mix & I can't imagine you needing much else.
Uncle E
JRR Shop
TEL: 949-553-8898
FAX: 949-263-1818
http://www.jrrshop.com
http://www.justroots.com
hifiboom
Post by hifiboom »
With Vinco, d-mute and De-Vice, there are pretty good compressors for Scope, but a quality and light on DSP EQ is another question, the DeVice ISOn seems too heavy for extensive usage...
I like the CW graph eq very much, but its also very heavy on the DSP load....
hifiboom
Post by hifiboom »
Hey Eric,
I did some sound samples with Vinco for fun that sound nearly like the Urei 1176 sound:
check out this thread:
http://www.kvraudio.com/forum/viewtopic.php?t=110148
By the way: I love the Orbitone compressors . They are also very good but something completly different than Vinco...
The quad-band multicompressor is very good for final mix and mastering.
It depends on the needs.
I think all these compressors for Scope are top-notch-quality.
<font size=-1>[ This Message was edited by: hifiboom on 2006-09-10 18:47 ]</font>
bcslaam
Post by bcslaam »
I see no mention of sonic timeworks stuff.
I will endevour to AB a few including those and post my results.
I will try the d-comp again I have it somewhere.
hifiboom
Post by hifiboom »
I do not have the Sonic Timework stuff... so I would be happy to see some A/B results...
if I remember this right those devices were programmed before it was common knowledge that spreading DSP code across chip boundary produces a few samples offset, hence they (may) have some phase issues.
Probably depends on project structure and loading sequence, it's at best unpredictable.
That does NOT mean the devices 'sound' bad and it may be irrelevant in 90% of all the applications - yet those facts hurt sales significantly.
This does NOT apply to the STW reverbs by Warp69 (P100/A100), which are from a later production date.
I like their Mastering Compressor a lot, plain and simple (as I can't stand surgery for loudness).
Works as a no-brainer with moderate settings, ear-ringing when pushed too far (no big news...)
In between it can add a little roughness (or a slightly 'aggressive' tone) imho.
Softknee version eats (almost?) 4 DSP.
<font size=-1>[ This Message was edited by: astroman on 2006-09-10 22:21 ]</font>
Tau
Post by Tau »
Just for the sake of argument, I have never tried DAS plugs, or ISON, and usually compress with Vinco or standard SFP comps (D-Comp too, very good for my bass guitar.
For EQ, I found that Wolf's SpEQtrum is truly excellent, both in sound quality and ease of use. You get 8 switchable bands of EQ, each with its own Q, gain and filter type controls, and you can visualize the filter curve over a real-time Spectrum Analyzer. The analyzer takes up a lot of DSP, but it can be switched off and unloaded to save resources. Also, SpEQtrum comes in many flavours: a stand-alone spectrum analyser, an 8-band EQ without the analysis, etc.
I think this is a bit of an overlooked plug-in, maybe because of a less-than-aggressive marketing strategy. I was basically interested in the Spectrum Analyser at first, but I found the EQ so good and flexible, I just use it on all types of material! Not sure if there's a demo, but it's worth checking out. Besides, the full version will come with YOUR name on it, instead of an anagram of some copyrighted brand name: how cool is that?
Cheers,
T
yes, we are very fortunate to have some really excellent developers here. Wolf's stuff is certainly first rate and his eq is excellent.
firubbi
Post by firubbi »
without a doubt :smile:
CS
Post by CS »
i bought DAS plugins (vintage bundle and SL9000). The EQs are very good sounding - and easy to use, which is not really the case of the SL9000... but they (at DAS) can help you if you need. As far as sound is concerned, this plugin is really fantastic, and its versatility very impressive. You can try them on their website.
my 2 cents,
cs.
King of Snake
Post by King of Snake »
I don't have much experience with other eq's (except the stock CW ones) but the Sonic Timeworks Vintage EQ is very good to my ears :smile:
Really smooth filtering, very musical.
