Intel Perl mainboards
FrancisHarmany
Post by FrancisHarmany »
So I am getting one as well. The idea is to take scope on stage one day, so stability is an issue.
Firewire would be nice too, anybody here have the D856PERLX ? Its supposed to have firewire onboard.
If I dont here any bad stories about the firewire version of the mainboard I'll get that one!
it works great!
GaryB pulled out my overbloated Supermicro P4SCT+II, and put in a D856PERL. At first I was shocked, for I paid 280 USD 4 it, and thought because the SATA controller from Marvell was run on the PCI-X buss, not PCI-e, that SFP would be fine on the 32 bit buss, and giga 's audio would go through the PCI-X buss. Turns out that all that fancy shit just isn't needed. Just more turns in the pipe which clogs up the water. I play live all day in studios, and matinee gigs, go eat and play for the dancing ho's here in Las Vegas. I can say that dog will hunt. Never once has it even coughed. If it would, I would dump it in a minute, and drag my Oberheims out of retirement. But this dog has hunted all year, and will continue to hunt as a SFP DAW w/ custom FOH / Monitor solution while I enjoy another SFP DAW with the Intel Conroe/ 965 combo for the synth from hell. Gary's word is as good as gold on these matters.
Don't Forget The Golden Rule,....He Who Has The Gold, Makes The Rules,
FrancisHarmany
its a pain finding one. I found one used, maybe I will get that. But its without firewire.
All other dealers are telling me they no longer have it.
Any online stores I can check ?
FrancisHarmany
Maybe we should test some newer intel mobo's ?
If creamware sends me some scope cards and mobos from intel I will be happy to test :razz:
Don't hold you breath on that idea. Check on Pricewatch.com. Or get the new Intel DP965LT w/ the cheap NVidia PCI-e video card, and the cheap OCZ PC2 RAM, and the cheapest Core 2 Duo CPU, the E6600. That is an inexpensive SFP set up which can be upgraded later when prices drop. This set up works well with Giga/SFP, and the VST Host and dual core work will be completed next week. I will then be able to run full masterverb pro testing, and IR1 testing w/ VST stuff, so I can post all results in the Conroe Thread here at the Z. As of now I only had a compatability test w/ SFP done. The E6600 runs as strong as the P4 3.0GHz. Quite a leap forward 4 Intel in terms of technology.
Strength Through Superior SHARC'S,
FrancisHarmany
Yeah I found some online dealers, mailed them all. We will see what happens!!
maybe I should get two :wink:
FrancisHarmany
Do you guys use the onboard USB ports ???
Yes,
I was using two for two USB controllers from M Audio 4 live SFP / Giga work. I disable them in the device manager and just use the USB to light up and power the controllers, then I send all info thru MIDI as USB for the power only is good 4 me. I hate wall warts and refuse to have them onstage.
Jimmy V.
<font size=-1>[ This Message was edited by: scope4live on 2006-08-31 13:39 ]</font>
yes, usb works.
typically on that mobo you must disable 1 or two of the 4 usb controllers in the device manager because of irq sharing, but all the ports still work normally after, so not an issue.
