NOAH forgets MIDI input assignments
Discuss the Creamware Noah
HiEnergy
Post by HiEnergy »
My NOAH EX always resets its MIDI inputs for the 4 multimode parts to MIDI when restarting the NOAH or the control software.
So I always have to set them to USB by hand when for controlling the NOAH via PC. The values seemingly are never remembered.
Does anyone here experience the same problem?
Any solutions?
spacef
Post by spacef »
have you tried the settings where you can lock some parameters (parameter lock i think).
Also, the wake up mode = last allows to switch Noah on with the last active setup.
MiK
Post by MiK »
Hi, i also have this problem, but meanwhile i don't think about it as it doesn't seem to be solvable. The feature to start up in the last configuration doesn't work for those in/out assignments of the parts, and i also tried this "lock midi ports" parameter in the setting - i think, my Noah just forgot this parameter also :smile:
The firmware is quite buggy. There seem to be lots of things you just have to live with. But if i find out how to really lock the ports to USB, i'll post here. Currently, i didn't have too much time to check out every corner of this nice machine.
