Looking for the case for my mobile studio
lagoausente
lagoausente
lagoausente
lagoausente
I´m in Spain. I asked Stilbox in Barcelona. They give me this price: 178 euro for a sigle case: 65cmx40x15 plust VAT.
The total would be 210 euro.
I think is quite enough money for spend on just a case to my like.
Do you know any thrift online store?
<font size=-1>[ This Message was edited by: lagoausente on 2006-08-02 11:28 ]</font>
What´s anvil?an old suitcase from the thrift store and some foam cut to fit......
or a custom case as made by anvil etc...
lagoausente
At the Uk's largest & cheapest 'catalogue' shop, 'Argos' which you can find online <a href="http://www.argos.co.uk/static/Product/p ... m">here</a>
Maybe you have a similar type of shop in Spain.
Only problems are that they often come in 3-piece sets like the one in the picture. Also, you won't be able to completely remove the lid (top) of the case, as all the ones I've seen are hinged. Removing the hinges would be possible, but a pain in the ass & the end result would be a weakened case. Still, there's hope for a cheap solution
lagoausente
The problem is have to buy the three.
There are many travel cases on shops here, but usualy haven´t the form of a aluminiun case, or they are not hard.
The ones on the photo, also can´t know what material are made with, the way they open..
I would prefer a hard case, like flight case, even it was used
I'd stick with an SKB by all means...
consider the value you carry around, the mess it will be to fit the cables and connectors to a 'regular' suitcase, the look (of the box and the audience) if you carry that box to stage...
I've recently had a 4 unit one in my hands (you probably need less), don't remember the price exactly but it was most certainly below 200 Euro.
at least get a fake SKB, those aren't as solid, but less than half the price.
lagoausente
Thanks for your replies.
I think the case may be not a problem for the cables. I need space inside only. Then, I´ll built sections, put foam etc.
I think the look is important, even I´ll be not on stage. Just don´t like a case that is clearly made for travel and cloth.
I have found cheap tool cases. I mean, for screwdrivers etc.., They look fine. Are usualy made of PVC. They are made to put in horizontal, and open the top. Many of the travel cases have zip. I don´t like that.
The problem is that the dimensions of those tool cases, are too low.
I have found one of 60cmx40x19 around 120 euro.
I´ll asume I´ll finally will have to go for one.
The only think I don´t like on that, is that the lid has low depth, so the depth is on the down side. So when I´ll put the things inside, they will be less accesible unless I put something under them, and so, will not take the most of the space avaible.
Look this one: http://www.kitther.com/productos_sel.ph ... 55&start=8
I would want something like this, but with the lid depth the same as the bottom depth aprox.
Sorry if I have mistakes on my post. I´m spanish.
PD: If anyone wants an Apogee, I´m selling one here: http://www.planetz.com/forums/viewtopic ... t=0#150411
<font size=-1>[ This Message was edited by: lagoausente on 2006-08-03 14:13 ]</font>
