MidioverLAN
Crickstone
Post by Crickstone »
Anybody using this with their system, and how hard is it to integrate with Scope?
erminardi
Post by erminardi »
I use Midioverlan since 2 years.
It's teh best way to transfer VST/VSTi power from another PC to main Host PC. (gigalan is IMO better for multiple insturments stream)
I also use in both PCs Creamware's Scope sytem without problems.
Midioverlan is transparent and uses CPU power, SCOPE uses DSP power.
Period.
Go for it :wink:
Crickstone
Thanks all....GigaLan is set and ready to go!
Kymeia
Post by Kymeia »
How do you get hold of stuff like Gigalan and Midilan and set it up for audio/plugins? All I can find is stuff about gaming - does it need a certain audio app to run it?
<font size=-1>[ This Message was edited by: Kymeia on 2006-07-11 00:11 ]</font>
a midi router application like midiox should detect the driver and allow connections, for example (as displayed in the router) LAN-midi-out to Scope-midi-in.
The latter shows up as a 'sequencer source' in SFP
cheers, tom
Kymeia
Post by Kymeia »
Surely that would have a lot of latency?
What about compensation algo.'s from the sequencer? Unless your playing live it shouldn't be that bad. Friends of mine have SFP/UAD, and Nuendo, and I don't notice any latency, and they use FX Teleport. I know live I'm at 6-8ms. About the time it takes 4 the ride cymbal to hit my ear.
synthetic88
Post by synthetic88 »
I'm trying to get this to work right now. When I do the port routing in MIDI-OX, it tells me that there's "No MIDI driver installed on this system" for the Creamware MIDI in. Am I doing something wrong?
probably.
i'll assume that you have installed the driver....are there sequencer midi source and dest modules in your routing window?
erminardi
Post by erminardi »
http://www.musiclab.com/downloads/free/
Use MIDI Connection Center 1.1 for free from Music Lab, it's a beautiful app that solves a lot of midi routing problems in my system.
:wink:
synthetic88
I had the source, but now that I have the destination it works. You need both?
Of course, 10 minutes after it's working, I get on a plane for a week. :cry: :cry:
elektrolurch
Post by elektrolurch »
Why not just connect by a MIDI cable from MIDI Dest to MIDI Source?
synthetic88
Well, I had problems using the hardware MIDI In (see my other thread). And MOL gives you eight or more MIDI ports without having to buy more hardware. I plan to have one for Scope and the rest running VSTs like GVI.
