A preset problem:
I allready had this problem before SDK with alfonsos dual-slot. It just saves the parameters of the Effect which is inserted in the right slot.
Now building own effects I experienced that my devices only save Parameters of inserted effects in Preset list, when they are used as inserts themselves. When using those presets outside inserts, which were made in an insert, they work!
Has this something to do with the insert-effect-shell? But the creamware multi-effect is an insert and saves values even outside inserts...
Maybe someone could help again.
Martin
In the manual there is something said about two ways of making presets, which I don't really understand... maybe I should try to understand that chapter.
Presets saving Parameters of inserted effects
Shayne White
You need to save your device as a .dev file (in the Save As... box). If it's a .mdl file it won't save insert presets. I had to find that out the hard way. I also think you need to make sure the insert slot's "path" pad is saved in the parameter and preset parameter lists.
Shayne
Shayne
Melodious Synth Radio
http://www.binary-sea.com
