LONG delay with INFINITE feedback for a
bosone
Post by bosone »
What about creating a delay module with several seconds of delay (BPM sync possible), with a feedback set up so that the sound is repeating endlessly at the same volume?
let's say that the delay time is 4 beat
you play a phrase of 4 beat and now the delay will endlessly repeat that phrase. of course since i don't think it's possilbe an auto-quantize, you should be very precise! :wink:
with a midi control, you can "bypass" the delay stage, so you can continue to play "over" the phrase you just recorded, maybe for an improvisation.
now you have two options: you can overdub a second phrase (using the same bypass on/off switch) or, with a second button (midi controllable), you can "erase" the delay memory and record a brand-new phrase.
now... imagine to have several of these devices, all connected in parallel, all midi controlled and all connected to different sound source... you can easily make a one-man-band improvisation :smile:
Listen to my music at
http://www.alchemystudio.it
<font size=-1>[ This Message was edited by: bosone on 2006-07-03 08:08 ]</font>
Shroomz~>
Post by Shroomz~> »
Astro mentioned that John Bowen had used a similar method in one of his sequencer designs, so it may be that what you're after already exists :smile:
wolf
Post by wolf »
MatrixDelay :smile:
Oberheim/Gibson Echoplex, but that is hardware. But the reverse looping is way cool. My Line 6 Echo Pro lacks the memory to do everything, so I use Celmos Tape Sim in additon to that, but I think I too will buy Wolfs Matrix Delay to help with this small dilemma. Astro speaks highly of it, and if he says it's good, that's all I need to hear.
See You Soon Herr Wolf,
sharc
Post by sharc »
I used to use Wavelength's Infiniti Delay for this kind of task. Maybe not quite what you're after (no BPM sync) but if you haven't checked it out already.... :smile:
http://www.planetz.com/forums/viewtopic ... 3&forum=16
Checked this one?
Shroomz~>
Post by Shroomz~> »
Atom, I think that patch could be packed into a standalone device or new modular module if it didn't use flexor.
Ed - just noticed it doesn't use Flexor after all ... :oops:
<font size=-1>[ This Message was edited by: Shroomz on 2006-07-04 10:35 ]</font>
MCCY
Post by MCCY »
at0m, is it O.K. for you, if I'd try to rebuild your device in SDK? Surely there would be your name on it. I would try to copy it 1/1.
Martin
MCCY
Post by MCCY »
LOOP-lay is ready for download!
