I took the first 40 original patches of the real Prophet 5 and entered them with BCR2000 to Noah.
A few notes on what I had to change:
Glide on the original are not effective unless UNISON switch is set on. On Noah the Glide is not disabled by UNISON switch. So for all patches with UNISON off I had to set Glide = 0 to make the sounds resonable.
Poly-mod Filter Env goes from 0-10 on original but (-?)5 to 0 and to (+)5. Center value (64 through CC#) is 0 and gives no modulation. CC# 0-63 seems to be a feature of Noah not on the original. 64-127 or 0-5 seems to match with 0-127 or 0-10 on the original so I converted all original numbers like this:
Poly-mod Filter Evn = 64 + (original/2)
Last thing I did might not be right: Modulation Wheel in full position sounds silly if FRQ A or B is selected for Wheel Mod. So I chose something near 2 instead of 10.
For PW and FILTER I chose 10.
This is purely my personal taste. Please comment
I notised that max value on original is usually 120 and not 127. This might mean that we need to scale some controls accordingly.
Also the Pulse Width seems to be reversed on Noah. However I used the numbers directly. PW of 59 or 60 seems to be center on original. I don't know yet what to do about it.
I have no idea how the original presets sounds on the real Prophet 5 but here you are. A first shot.
After some feedback I will finish my PC program which converts original SYSEX one by one to the Noah for the 80 remaining Factory patches and 2 extra sets of 40 that I have found on the net.
So now please play with them, adjust them and give some feedback. Escpecially if you have the original P5
 Then perhaps you could provide a few sound-samples of the original sounds.
 Then perhaps you could provide a few sound-samples of the original sounds.Henrik.
http://www.planetz.com/forums/viewtopic ... &0&start=0
<font size=-1>[ This Message was edited by: Henrik on 2006-06-22 17:10 ]</font>
