scope 15dsp power usage
tripstation
Post by tripstation »
Hi Dudes,
does anybody know how many watts these use.
regards,
Jimi
Asus PC-DL delux
Winxp Pro sp1
Nuendo 3 / mLAN
Gigastudio3
Native Instuments Komplete 2
2*xeon 3.06ghz
2gig ram
wd raptor 74gig system
wd raptor 74gig audio
Scope pro 30dsp (stand alone pc Asus P4GPL-X, Win XP sp1)
<BR
no, but i do know that a good quality name brand(like antec) 450-500watt is sufficient. if it's a no-name supply(not recommended)the at least 550-600watts should do. bigger is better in this case, so i'd get as big of a supply as you reasonably can afford.
i have seen 1st quality supplies of 250watts out perform 500watt cheapies, so quality is certainly at least as big of an issue.
tripstation
the reason I ask is cause i'm trying to build a 1u scope server with a pentium m cpu.
So I needto know the power consumption of the Scope 15 DSP cards,
does anyone know where this info is,
regards,
Jimi
Asus PC-DL delux
Winxp Pro sp1
Nuendo 3 / mLAN
Gigastudio3
2*xeon 3.06ghz
2gig ram
<BR
Stige
Post by Stige »
There was some info about this in the old creamware site. but now it seems to be gone. I'm sorry not able to recall the exact power requirement. But it was at least 15W for 6dsp card. There are some limits what a pci slot can deliver. If I remember right, that is 25W.
Perhaps someone knows the exact numbers.
jea
Post by jea »
As to what PSU to choose, take a 450 or larger one.
If you need exact data, CW knows....
eh, you're right, :-) I am a luna(t)ech!
djmicron
Post by djmicron »
from my old scope srb technical specs,
the power comsumption is 15 w.
djmicron, 6W per chip would be more like it. 6W is also about what a normal consumer's soundcard uses...
Check this calculator: http://www.jscustompcs.com/power_supply/
ali
Post by ali »
according to creamware General specs:
3 DSP card has a power consumption of 6 W
6 DSP card has a power consumption of 7.5 W
15 DSP card has a power consumption of 15 W
Oh, I'm sorry... never expected them to be so lean!
tripstation
15Watts, cool.
thanks dudes.
regards
Jimi
Asus PC-DL delux
Winxp Pro sp1
Nuendo 3 / mLAN
Gigastudio3
2*xeon 3.06ghz
2gig ram
<BR
Check out OCZ Powerstream if you are going to be using multiple HDD's. I use a little 865PERL w/ 3.4EE Northwood, and 3 x Raptors. You can adjust your rails on the PSU to suit your consumption needs.
More Has Been Destroyed By Less,
