vincoDT bug report
bosone
Post by bosone »
i found a small bug in vincoDT, can someone confirm?
the problem emerged as i was doing the following:
i set up a mono channel strip (stm2448) with some inserts: gate, vincoDT, Tdrive, Dynatube
i save the channel setup as a preset in the mixer.
now i load the setup i just saved in another channel strip
the problem is that i cannot open the insert control surface of Tdrive and dynatube
the same happens if i load dynatube and use vincoDT as insert (both pre or post) or if i use the mutliFX insert slot
i did some test, and i found that if i use vincoDT as insert, i cannot open the FX surface of the effects that i insert after it. i tried with other FXs and the results are the same.
so vincoDT creates some problems....
to recreate htis problem:
load VincoDT as an insertFX in some slot (both in the mixer 2448 or in dynatube or in multiFX mono) and add other insert FX (i tried PEQM, TQdrive M, Tdrive M, autowah, etc) after vincoDT.
now save a preset with this setup
try to load the preset for example in another channel strip or in another instance of dynatube
the control surfaces of the insertFX placed after vincoDT cannot be opened
bosone
Post by bosone »
i'm the only one who experience this?!
