MSI K8N Neo4 Platinum [a luky upgrade!]
erminardi
Post by erminardi »
I've upgraded my Carillon audio PC from Intel PIV 1.5Ghz, 768 Mb ram, AGP ATi videocard, Silent Molex radial cpu fan, to:
- MSI K8N Neo4 Platinum
- 2x512 Mb PC 3200 Dimm Kingston
- CPU AMD Athlon64 3.500 Ghz DH
- GeForce 6200 videocard DualHead (no fan, passive heatsink!)
- Zalman 7700 Al-Cu super silent CPU fan
My sistem features 2xUAD-1 and 2xScope Project, Cubase SX 3.2, Wavelab Lite, various N.I. soft synth, FX-teleport and Gigastudio 160.
After 2 days of hard testing, I can say that all seems to be stable. No strange beahaviors or blue screen :smile:
Win XP sp2 with XP lite action, Tweak XP, and Registry Mechanic.
Nothing disabled (hyper threading or similar.
The "AMD Cool and Quiet" feature is amazing: the noises are very, very low!!!
The mainboard is quite expensive, but is very top of the class, full of optionals (round cables, additional bays, accessories, etc.), I've selected this MoBo beacuse the 4 pci slots available + 3 PCIe slots + 2 Gigalan + Firewire + a lot of USBII integrated.
The CPU cooler is also amazing. A good alternative is "Arctic Cooling 64 freezer pro", also quiet and powerful.
I think that the MSI K8N Neo4 Platinum is the last >3 PCI slot remarkable motherboard of the market.
The 3.500 Mhz CPU version of AMD K6-64 is better than 3.200 or 3.000 because the lower Watts absorption and consequent lower heat produced.
A luky upgrade :grin:
Cheers!
ps. the results??? The new system, at standard BIOS settings (conservative setup) works 3,5 x old system!!! :eek:
All of my old biggest projects are now under 33% and the ULLI can be set at lowest step!
<font size=-1>[ This Message was edited by: erminardi on 2006-04-22 06:25 ]</font>
sharc
Post by sharc »
That sounds really cool. Is that 33% cpu/dsp? Any chance of a Masterverb test?
erminardi
Post by erminardi »
Please, let me know how to make a PCI performance test?
Do I must load a lot of plugins?
Can anyone explain this?
Thanks.
erminardi
Post by erminardi »
The 33% is about AMD CPU usage. The DSP usage is obviously the same as before.
Ps. the last beta BIOS resolves a lot of stability issues described in other threads. (Nforce4 versus Nforce3, ecc.)
My only real "fear" is that MSI MoBo are described as "fragile" in durability...I really hope that's false! :wink:
Scope 4.5 + 2xPulsar II + 1xLunaII + 1xPulsar1 + a lot of devices = Pure Joy :smile:
<font size=-1>[ This Message was edited by: erminardi on 2006-04-22 12:55 ]</font>
alfonso
Post by alfonso »
Thanks.
There is a thread here:
http://www.planetz.com/forums/viewtopic ... orum=19&72
You just have to load as many Masterverbs in a totally empty project until you reach PCI overflow error...naturally if you only have 12 dsp's you will probably have a dsp error first...that is ok. If you get a pci error before a dsp error tbat's the indication of your pci buss limit.
:smile:
bronYaur
Post by bronYaur »
the HT of AMD as hyper transpor bus enanche
the HT intel is hyper treading pipeline enanche
<font size=-1>[ This Message was edited by: bronYaur on 2006-04-22 14:02 ]</font>
erminardi
Post by erminardi »
Thanks, tomorrow (or one of these days) I will try the Masterverb test.
Soon here will comes the report :wink:
Anyway, the reverbs are the only SCOPE plugins that requires a lot of PCI band because the need of system RAM.
This is not a real problem for me because I prefer the UAD's Dreamverb. (I work in XTC mode)
On 2006-04-22 06:20, erminardi wrote:
...The "AMD Cool and Quiet" feature is amazing: the noises are very, very low!!!
The mainboard is quite expensive, but is very top of the class, full of optionals (round cables, additional bays, accessories, etc.)...
it's listed between 100 and 160 Euro (avg 120) in Germany - or did you get it with a lot of extras ?
The bad reputation of MSI seems related to a certain type of capacitors they once used and which didn't last very long - dunno if that allows conclusions about their general design quality.
erminardi
Post by erminardi »
erminardi
Post by erminardi »
paid 120 euros plus vat...
Shroomz~>
Post by Shroomz~> »
How are you running 4 Scope cards?
Can you try Alfonso's Masterverb test & post the results on the thread in the link he gave you above?
erminardi
Post by erminardi »
No, only 2 cards = 12 DSP (SCOPE)
The other 2 are UAD-1 with onboard RAM -> heavy PCI band not required.
Shroomz~>
Post by Shroomz~> »
Ah, I was reading your signature.
The reason for asking you to perform the MV test & post the results for us, is to enable a better picture to be drawn for people upgrading mobos etc. For example, you may not feel the need to do the test, but if someone has 2 or 3 SCope Pro boards running 30 or 45 DSPs & want to upgrade their mobo, they will most definately want to choose a mobo which performs very well in the MV test, such as Her Voigt's.
erminardi
Post by erminardi »
On 2006-04-23 04:04, Shroomz wrote:
Ah, I was reading your signature...
Yes, my signature is correct, but in my Host PC i have 2 Scope project in XTC mode [M'n'M pack], and in other PC (synth) i have installed 1 Scope home and 1 Pulsar 1 in SPF mode, as external synth [S'n'S pack].
erminardi
Post by erminardi »
I've realized the Masterverb test:
6+6 DSP = 16 Masterverb
Limit DSP reached but no problem with PCI band overflow. :smile:
<font size=-1>[ This Message was edited by: erminardi on 2006-04-23 16:22 ]</font>
next to nothing
Post by next to nothing »
exellent results!
Eminardi, would you mind to run a few sequencer tracks in a loop through your UADs and check if it has an influence on the number of MVs you can load ?
Shroomz~>
Post by Shroomz~> »
Hi, just to clarify. Did you get 15 Masterverbs & reach DSP limit on 16 or did you get 16 without a single pop-up message?
Shroomz
erminardi
Post by erminardi »
Shroomz
16 without popup and only a red line at the end of DPS meter. 17th says that DSP are not enought.
UAD cards requires a relative low usage of PCI band, no problems in XTC: 16 Masterverb plus a lot of UAD's reverbs & others EFX.
Below 8-10% CPU consumption at 7ms ULLI!!! :eek:
My BIOS ver 1.A 110405, also available 1.B official update or 1.C beta update (only for win2k qiet control problems). All works ok for me, then I remain with 1.A.
For everyone that love overclocking is also available the Dynamic Overclocking Tecnology, works safely but it raises heat & noises problem for audio users...
Today I will experiment with CPU/system downclock: I wish to see if the temperature goes down.
i.e. from 3.500 to 3.200 Mhz, the power is anyway enought for me :wink:
erminardi
Post by erminardi »
After a lot of experiments I have the definitive verdict: the Zalman 7700 Al-Cu heatsink is better than Arctic Cooler Freezer 64 pro because his radial dissipation that sink all the system around. The Video card temperature goes to 69°C instead 76°C.
All without any case exsaust air fan!!!
All the system goes down with temperature compared to the previus CPU heatsink Arctic Cooler Freezer 64 pro.
Results after 8-10 hours run:
- CPU temp: 50°C (it was 54°)
- System temp (MoBo): 47°C (it was 51°)
- GeForce GPU temp: 69°C (it was 76°, warning treshold is 145°C)
External enviroment temperature today: 28°C inside my studio.
Noise are very very low, I can record my guitar/voice in front of the desktop case at 50cm of distance!!! :grin:
Here the topic about the heat problem:
http://www.planetz.com/forums/viewtopic ... forum=1&15
