Tool for creating sampler kits.
lagoausente
I have found that STS have some problems with stereo samples. Seems the only solution is convert each stereo to two mono ones and correct panning it.
Making programs on STS are really anoying. There is a tool from King Blue on this forum that allows to add lot of samples from a folder at once. The only problem is that it creates one new keygroup for each channel and cannot use the 4 samples of each keygroup.
Is there any tool to easy compile sampler programs on other format, like Akai, Giga etc, to can convert then to STS using CDxtract?
- Shroomz~>
STS & Akai format are very similar. As long as you have the Adaptec ASPI layer installed, STS should be able to recognise Akai 'Programs' using the Scope 'file browser'. You could compile your sample programs in something like Chicken Systems 'Translator' as either STS or Akai format (Akai being more universal) & load the programs into STS.
djmicron
lagoausente
lagoausente
As you know I´m new on STS. Since I know, I can only add 4 samples (4 zones).On 2006-04-15 11:28, djmicron wrote:
p.s.
is it not more easy to add samples directly into an empty keygroup instead of using the blue king tool ?
i want to build a drum kit. For snare, for example, I want to use several samples for different velocities. Even more, want to have, direct and ambient samples. I have 43 velocity on snare x3= 129 samples. Seems no good adding manually, the same for bass drum, toms, etc.
lagoausente
Seems sample robot don´t admit 24 bit samples, and Samplit don´t allow import samples. Any other idea?On 2006-04-15 09:09, djmicron wrote:
there are 2 very useful programs that i know.
one is samplit
and the other is sample robot
<font size=-1>[ This Message was edited by: lagoausente on 2006-04-15 14:37 ]</font>
djmicron
inside the king blue utilities there should be one called stsadd, that is useful for automatic drum keyranging.
Another good software to create sample instruments from existing audio files is constructor http://www.chickensys.com/products/sw_i ... onstructor
lagoausente
The ADD one is the one I have told I´m using. It works ok.
I was just looking for a tool with many other posibilities, even working on Giga or Akai format, to then convert to STS, since in STS there seems not be a great tool for this.
I´m looking in other forums aswell.
Constructor seems interesting tool.But can no see Demo avaible, and seems a quite expensive.
<font size=-1>[ This Message was edited by: lagoausente on 2006-04-15 17:34 ]</font>
<font size=-1>[ This Message was edited by: lagoausente on 2006-04-15 17:51 ]</font>
lagoausente
Till now I have found that combining Gigastudio Editor and ADD tool, can do some work.
With Gigastudio Editor can make a template for diferent key velocities. Just create an instrument, a region and number of split velocities.
Must load a sample to can save the gig.
Then convert to STS, and you´ll have one keygroup for each velocity split, with velocities well suited, 1-5, 6-10 etc.
Now, just use ADD to add a list of samples. If they are alphabetically well named, you´ll have the work done. Hope this helps, and hope anyone can give any other tricks.
