Right now I've installed in my pc 2 OS: winxp and win2000, but I'm not completely satisfied because the machine doesn't seems very stable.
I've ACPI installed and some IRQ conflicts, so maybe that's the cause.
Which OS do you suggest to install? There's some features a OS gives that I really need and I miss if I will use another OS (like installing win 98 instead of winxp for example)?
My situation is the following:
my pc isn't updated: Asus Cusl2C with pentium3 800, matrox g450 and 512 MbRam. At the moment I haven't money to change it. I don't need Vst's or any other evolved CPU intensive programs (like the last sequencers for example) because I do everything (except recording) with scope.
I use the PC only to make music.
Last question: which SFP software? Can be senseless to install the 3.1c instead the SFP 4.5? I've read in different topics that the last scope is the same of the 3.1c, but someone have experimented troubles in win xp but not under win2000 (I've got in mind the Aries's strings). Can be possible that in the last release some dsp files are different?
Any idea is well accepted! Thanks!
