i have 2 OS installed (normal and music), each one sharing the same SFP directory.
the startup project is rather "complex", being the music one specifically suited to my needs.
on the other half, loading such a complex project in the "normal system" takes quite a lot of time.
i have 2 choices:
1) reinstall SFP in the normal system in another directory and set up a smaller start-up project.
2) find a way to load a different project at the startup... is there a way to edit the win registry and load another project beside the startup one? SFP should also, of course, be loaded minimized...
thanks!
how to change the startup project?
bosone
