A16 ultra level question
Wired
When i output a tune from the optimaster at -0.1, i place it thru my drawmer mercenary edition at 0 threshold, and unity gain, and i find when i record the result in the vdat i find (i check in soundforge) it is aproximately -6 db, i wish the levels would remain the same as i don't use the drawmer to compress, but it seems i have to boost the output gain of my drawmer up 6db. so are my switches at the back of my a16 mirroring incorrectly?, or is the analog gear, what i want is just to pass thru the audio, but maintain the optimasters levels,
thankx, could garyb answer also?
voidar
I suggest you try a different dip-switch if you suspect it being mirrored wrong.
Else from http://www.jlmaudio.com/8packoftrans.htm:
# The list below shows some of the more common settings.
# +22dBM for Protools HD Protools 888 Yamaha 02R input Mackie HD System Mackie DXB-200
# +20dBM for Aark24 ESI Juli@ Apogee Rosetta 800 with internal jumpers set to match +20dBu
# +19dBM for RME Multiface and Fireface
# +18dBM for Protools 882 Digi001 Digi002 Paris MOTU896HD
# +15.1dBM for Hercules 16/12FW
# +10.8dBM for Creamware A16 MOTU 2408 mk II Alesis A13 (Needs 7dB pad)
Wired
right,the trick is to go out and in at the same levels. However it would be nice to maintain at 0.1db, not -10v or +4v for i/o, since i only use an outboard comp for passthru. sometimes i wish the unity gain and the threshold at 0 would enable the levels to stay the same, but going in and out of the a16 causes one to 'make up' when you go outboard
- garyb
- Moderator
Wired
thankx, i do find the drawmer 68 merc edition with the big switch adds alot of beauty of depth and glue to the finished product, but common opinion is that its euphonic tone sometimes find it mushy , i find that if i crank the output stage it mushes up, does anybody find another comp useful in this, i hear the tube-tech does a better job (almost double the price, tho), any suggestions?
- garyb
- Moderator
optimaster?
vinco?
both pretty darn good and no need to go outside the box.
ditto stw mastering comps.
why do you need a compressor on the final mix? a properly used limiter can work wonders, even a cheap one, but an improperly used limiter will make poop even if it's expensive.
one nice thing about a multiband like optimaster is that you probably want to limit low freqs differently than mids and highs. a really good crossover and really nice limmiters will do the same job, but at a crazy price and requiring more skill.
actually, if you are unsure about the best use of such tools, you can take your finished mixes to a good mastering house and pay attention to how the engineer does his job, an education worth the money. when going to the mastering engineer, it's best to not have put a limiter on the whole mix anyway. be assured that as nice as the drawmer and it's ilk are, these are pretty coarse tools compared to what a true mastering room can offer.
vinco?
Wired
i use all the creamware stuff, my tunes are all done via the opti, but the final touch, high end circuitry adds depth and roundness to the mix, the reason people buy external gr is for a gentle passthru, (the sharc chips via vdat recording also adds depth compared to wave dest.), maybe its just that little more i'm looking for in a mix which the drawmer gives me. I find in some mastering houses, all they use is protools, and it doesn't do much to the overall image we can get from cw, i'd like to try this last bit form brainworx to see if there is any improvement
Wired
ya, if you go "out", make sure you have a good low noise comp, i go out a16 via adat, and back, i have actually gone from the SBC (after mix LR)into my ext. comp, then into the optimaster, i find that its ok. Because my goal was to get the analog "breath" from the ext device, i still find its somewhat maintained after going back into the opti for limiting. Otherwise you have to play witht the analog gr. The big question is if your actually making a cd with 1's and 0's in the end anyway, how can you really maintain that analog sound, i think its the final ad's in mastering, i hope the a16 and vdat fill that roll for me as many mastering houses just use protools anyway
