EXCEPTION. no board installed
ARCADIOS
Post by ARCADIOS »
i got this message after trying to raise polyphony on prodyssey.
actually i use scope in lower priority, might that be the cause?
after i confugured cset.ini and i use pulsar2 6dsp as 1st board and scope pro 14dsp as second board.
this way i can reach higher dsp load easier with less f... errors
yes, using lower priority might be the cause of your problems. you don't need to do that with sx, normally. sx opens in "above normal" anyway.
ARCADIOS
Post by ARCADIOS »
nuendo when zooming there is a specific point that starts loading from the hard disc of the project. the bad thing is that nuendo takes samples in many zoom levels from about half zoom to full 90% full zoom in, then when you have zoomed in at the max it is ok, but after when you zoom out again it starts taking samples by loading many times, and when loading the movement of graphics in nuendo gets stucking.
sfp mixer shows stucking level singals.
i read somewere that setting sfp in lower priority will not let scope graphics stuck.
yes nuendo is set to above normal.
sfp when nuendo plays and loads from hd makes some stucks.
i do not know what to do about it.
i just think that sfp in lower priority is somehow lighter on graphics demand. maybe wrong.
anyway... has anybody fixed this stucking steinberg issue when zooming?
and another question here. what should the relation between scope cards and graphic agp card latencys should be?
