Windows XP Pro Setup error
ChrisWerner
Post by ChrisWerner »
I decided to structure my whole system new and install everything again from scratch to organize my DAW in a better way.
I setup the primary C partition with 8GB for Windows and started to install Windows.
Now the win setup tells me an error.
Error code 800b0101.
It says that the system file time is invalid. I should check my computer date and time in the BIOS. Well, did it, it´s the actual time and date. Also tried to set it back to 2001.
I´ve an Intel D875PBZ main board and an old Windows XP Prof. Maybe both won´t work together? Do I need a newer Win XP version?
A friend of mine suggested me to do a bios reset, remove the battery, short both contacts and wait some minutes. But I feel bad with that somehow.
What to do?
xp and the d875pbz are fine together normally. maybe a bios reset is in order, but if you do that, i might think you'd start over and repartition again as well.
ChrisWerner
Ah could sort it out, a time bomb windows version, great.
My windows version has a use-by date certificate. Thank you M$.
EDIT: I had to set back system time to 05/03/2003. Awesome, isn´t it?
Music starts where any language ends<br>
<a href="http://www.spring-of-sound.de">Spring-Of-Sound.de</a>
<font size=-1>[ This Message was edited by: ChrisWerner on 2006-03-03 00:57 ]</font>
:grin:
ChrisWerner
Well it´s true.
http://www.heise.de/newsticker/result.x ... l&words=XP
german language, though.
ChrisWerner
Yep, works now. I totaly forgot how quick Win can boot. Haha.
H-Rave
Post by H-Rave »
And they all lived happily ever after.mnaaaah ...I love happy endings(Fades out to music)
