Hello,
I have a strange problem. One of my PCs won't boot from a bootable Ghost GDisk CD that I created nor from a bootable Ghost recover DVD that I created. However, these discs will boot on my other 3 PCs. The PC where it doesn't work will however boot from my XP CD and my Acronis boot CD (which I created). The problem PC though will boot from my Ghost floppy bootable.
I don't understand why this is the case! As I said, the bootable discs I have created work on all my other machines, so I know I have made no errors in the creation process. I have tried everything that I can think of. I have checked the BIOS. Everything seems OK there (but as I said the XP discs boots and so does the Acronis disk).
In particular I wanted to boot from my Ghost GDisk so that it would wipe my drive clean. What I have also done is make a bootable XP Floppies, boot up with those then in DOS find the drive where my G disk is (for example-E: > Dir > which finds the contents I see the GDISK.EXE file > type GDisk.EXE> but it tells me that it is an invalid command)
When I have tried to boot with the bootable GDISK CD it just hangs on start up and nothing happens. I have tries to make a bootable usb key too but that didn't work either. It seems my BIOS doesn't allow booting from USB.
This problem is driving me nuts!!! I hope I have made clear what the problem is and that someone out there can offer some help. As I said, these discs work on all my other PCs.
Could I solve the problem by changing the DVD drive? Though that seems drastic and as I said it boots my XP disk and Acronis disk.
Thanks in advance for your help!
P.S.
When I boot up in DOS have I typed the correct command?
Boot Disc Problem
Astral Fridge Magnet
Hello again,
I have decided that maybe a firmware upgrade will solve the problem. Before I do a firmware update of my DVD drive I just want to make sure I do it properly before attempting it, so I hope someone out there can explain it to me as I can't anywhere on the net any information on how.
I have managed to find an updated firmware update and unzipped it to a floppy. I have checked it is the correct one for my particular drive with a utility called NeroInfo Tool, which I got from the following site:
http://www.iomagic.com/Firmware/NeroInf ... otool.html
Now I know that you should avoid doing firmware upgrades unless absolutely necessary, but because my DVD drive won't boot certain bootable DVDs (that work on other PCs), maybe a firmware upgrade will help.
Am I supposed to just double click the file I downloaded? There is no information on how I do this on the manufacturer's site.
Thanks again in advance for your help.
