i was reading an article in computer music, about getting a better bass sound. it was talking about sending the bass through a delay, and having the bass hit dry, then putting a filter, distortion, and maybe even reverb on the echo. how would one go about doing this?
the only way i could think of, was to automate the fx to come on and off? but is there some way to route the signal so that only the echo of the delay gets filter/distortion/reverb, or any other fx?
A question about FX...
symbiote
Just load the delay/dist/etc as an Aux, then you can have the dry signal in the channel and send some of it to get delayed and distorted etc.
You could also use up a second mixer track, i.e. have one mixer track with the dry signal, and another with a filter/delay/distortion. Just set the delay to 100% wet.
___crisis___1
- kensuguro
symbiote
No, if you load the filter/delay/dist as Aux effects and set the delay to 100% wet, only the delay/echo will get effected, the main signal will remain completely dry.On 2006-01-15 08:22, ___crisis___1 wrote:
ok... but once you have it all setup, you still have to automate the aux send, or the mixer channel right? cause if not, then th whole signal will get effected.
You can still automate the Aux, but that will only control how much dry signal you send to be effected (i.e. control the amount of delay,) not if only the echo gets effected.
- alfonso
For the best bass sound is good to process its mid-high & high spectrum, leaving the bass bottom untouched, otherwise you loose punch.
Check this device:
http://www.planetz.com/forums/viewtopic ... orum=16&15
Check this device:
