PCI capacity limit reached problem
Guest
Post by Guest »
As soon as I use a few asio or asio 2 dest, I got a PCI capacity limit reached (b.e : with 24/96, it occurs when I use more than 10 asio2 dest.
It often occurs when I use a pulsar midi device like sample player. It seems to work a little better at 48k, but it is not an orgy)
my config:
AMD Duron 800
Abit KT7 raid
384Mb RAM
Pulsar I+
12Gb HD (next purchase: 2*45Gb HD for Raid)
Zindoz 98se (WinMe really sux)
VST
plz help
Guest
Post by Guest »
Subject: Via chipset
Via chipset cause probably this problem , i have same problem in similar mb Abit with old AMD K7 900 socket (and sorry for my English , i am Italian )
Guest
Post by Guest »
Subject: try a new bios version
the problems with limited pci bandwidth seems to be gone with later bios versions.
so maybe all you have to do to solve your problem is to flash your bios.
Mo
Guest
Post by Guest »
Subject: stesso problema....
Ciao!Sono anch'io italiano...
Ho il tuo stesso problema..Ho un k7 a 1ghz e chipset via,e quando arrivo ad usare 32 bit in cubase e driver asio2 a 24bit il mio bus pci va in overflow...la mia scheda madre è una soyo k7vta-b
Guest
Post by Guest »
Subject: Maybe for KT7A... I have YH bios and It sux too -noTxt
subhuman
Post by subhuman »
I suppose most "power dsp" users would have moved onto a different chipset now in search for best performance but if not, <a href=http://planetz.ghostwheel.com/forums/vi ... um=3&3>try this</a> may help a tad.
bosone
Post by bosone »
try to install the latest via4in1 drivers, that you can found in via website (don't remember the adress, sorry!)
