CW VA synths behave weird (noise, polyphonic mode)
kybernaut_01
Post by kybernaut_01 »
CW synths behave very un-musical when patches using "noise" are played polyphonically.
I mean those overlay/cancellation/phasing type of sound. I noticed this with Minimax, Pro~One, Profit-5, Prodyssey.
I think, once again, the problem here is how CW approaches polyphony in it's VA devices: They make 1:1 clones of one (monophonic) modeled voice.
Most obvious example here is Profit-5 (Pro~12), which is modeled after a real polyphonic synth and should thus behave as such.
AFAIK, technically one(!) noise generator is proportionally routed into each poliphonic voice on analog synths. Thus no ugly cancellation and no unproportional levelling problems.
Why is this so hard to implement on a CW device?
kybernaut_01
P.S.: I'm not an happy owner of a real Prophet-5. So if anything outlined here is wrong, please correct me!
maybe it was simply overlooked ? :wink:
good point - you probably mean that the noise either adds up or subtracts overproportionally due to the same copy applied to all voices.
kybernaut_01
Yes, one thing is the level. The other is color of the sound that changes after every keystroke (comb filtering...)
cheers,
kybernaut
Shayne White
Post by Shayne White »
This is usually fixed in the Modular or SDK by setting the noise source to be monophonic, but unfortunately you can't do that in the pre-set synths. Don't know why CW didn't do it themselves, because these devices were made in the SDK. :sad:
Shayne
Melodious Synth Radio
http://www.binary-sea.com
Herr Voigt
Post by Herr Voigt »
To handle distorted or noisy sounds polyphonic is a difficult thing. Many years ago I learned from a guitarist, that thirds or sixths on a distorted guitar don't sound very well. I checked it - he is right. Only monophonic solos or power chords are recommended. Other intervals or full harmonies(incl. dissonances) may cause some special and strange effects, in most cases they are unwanted.
Maybe this is similar to your problem. If you take a noisy preset to make harmonies, then turn back the noise osc level - perhaps you should connect it with a MIDI controller?
On 2006-01-01 06:59, kybernaut_01 wrote:
...The other is color of the sound that changes after every keystroke (comb filtering...)
well, if the noise shows a comb filtering effect then there must be a small time displacement on the 'per-voice-copies' of the single noise source.
whatever that means...
cheers, tom
kybernaut_01
cheers, tom
Yes, something along these lines. Very strange indeed. This comb filtering effect occurs whenever you play polyphonic lines on the said CW devices... And also, when you switch the Profit-5 into unison mode.
@Herr Voigt: I know what you mean. But I refer more to how analog synths handle the "Noise" source - and how Creamware does it...
<font size=-1>[ This Message was edited by: kybernaut_01 on 2006-01-01 15:10 ]</font>
oops - sorry for messing things further and not naming the source immediately.
Of course it is a time shift that causes the 'comb filtering' - and it's absolutely regular, as it's... the fx unit :razz:
go to the fx page (in the profit), switch it off and it will sound as analog as you expect it :grin:
cheers, tom
kybernaut_01
Yawn ... :wink:
I have no level or cancellation problems, let alone comb like effects when the FX section is off
What's the point that I miss ?
curious, Tom
kybernaut_01
curious, Tom
Hi Tom. Mine sounds like that (and there is definately some comb filtering going on):
http://home.arcor.de/kybernaut_01/minimax_noise.wav
http://home.arcor.de/kybernaut_01/profit_noise.wav
cheers,
kybernaut
Shayne White
Yeah, that's definitely because the noise is polyphonic. There's nothing you can do about it. :sad:
Perhaps you could write to CWA and ask them to fix it? It should be an easy thing to do on their part. It definitely should be fixed in the ASB boxes. :smile:
I wonder how Arturia's stuff behaves? I don't often use noise sources so I've never thought about it. Next time I'm in my studio I'll check it out.
Shayne
it sounds as if the keytracking og the filter is on, isn't it ?
rounser
Post by rounser »
What's a power chord? Octaving, as in C2 C3 C4?
sexeless, no (minor or major) third :smile:
kybernaut_01
astroman, I'm well able to press an FX bypass button and to get the influence of a filter out of the way, thank you :wink:
The easiest way would be to try it yourself. If it sounds different on your system, it can still be a NOAH vs Scope difference.
best,
kybernaut
P.S. BTW. Keytracking on a lowpass filter isn't able to tear a notch at 2.6 kHz...
<font size=-1>[ This Message was edited by: kybernaut_01 on 2006-01-03 04:54 ]</font>
On 2006-01-03 04:40, kybernaut_01 wrote:
...The easiest way would be to try it yourself...
so what do you think my impression is from ? :razz:
I HAVE done exactly that and I do get exactly the sound of your example WITH filter keytrack on my own copy of Profit5.
maybe you should have posted your preconditions more precisely ?
you could have mentioned that the obvious suspects as delay fx and keytrack have been rulked out and that you write about the NOAH version.
what about your own theories regarding CWA's abilities how to implement analog stuff right ?
kybernaut_01
Sorry, thought that this would be self-explanatory. And differences between NOAH and Scope versions of these synths do not exist, as far as my experience goes.
Go and check an arbitrary analog polysynth of your choice.
Another thing is the phase-locked oscillators in CW devices. There is no way, that two different analog oscillator circuits do not drift in some way.
The third issue (which is not limited to polyphonic CW synth) is the lack of typical attack behaviour. Has been critisized by "Keyboards" more than one time (Minimax).
cheers,
kybernaut
<font size=-1>[ This Message was edited by: kybernaut_01 on 2006-01-03 05:48 ]</font>
johnbowen
Post by johnbowen »
Hi list,
the polyphonic/monophonic noise issue is something the designer of the synth can set. For some of my synths, I put a switch in to choose, but usually I make it a mono noise signal, since I personally prefer not to have the 'comb filter' effect when I play polyphonically.
john bowen
bowen synth design
zarg music
kybernaut_01
So if this can be set by the synth designer, as Shayne White and John are pointing out, I'm really wondering why CW decided to implement it the way they did.
It must be a rather concious decision as it has been done that way on all their VA devices. But why? It sounds unmusical and is not true to the original hardware.
kybernaut_01
P.S. I will will send email to CW. Let's see if I get an answer.
