Question for ScofieldKid
bronYaur
Post by bronYaur »
I have read:
"It's hard for me to add helpful comments on Scope in this setup however, since my Scope Pro is I believe having a hardware issue with one of the DSP's. I'll likely be sending the card in for repair..."
Also i have the daugerdboard of output of my scope in repair,system samplerate no found and scope no get audio ,block all SPF system, fortunately I have 2 scope and 1 scope SRB and the scope damaged i use only DSP board
What kind of problem you have with your card?
That errors were manifested in the system?
Thanks for one your eventual answer
Daniel
Italy
<font size=-1>[ This Message was edited by: bronYaur on 2005-12-25 10:00 ]</font>
ScofieldKid
Post by ScofieldKid »
Thanks for the interest.
My problem was really just understanding what the limits of the Scope system are. Using the Masterverb Pro test I believe that I have my system optimized and working as best as can be expected. So probably not helpful/relateable to you situation.
Merry Christmas! (by the way)
Best of luck with your problem.
bronYaur
Post by bronYaur »
Thanks to you for the reply
Best Regards
