flexor instal problem
vipal
Post by vipal »
when i ordered flexor i got the activation key from creamware. now when i put the flexor no keys oxe file in app/oxe, when i start up my scope 4.5 i dont see flexor anywhere in my routingwindow and there is also no keyactiv. procedure call. any hint? how to get my flexor working? i am very curious how flexor sounds. also looking fwd to find some nice bass patches.
vipal
Post by vipal »
maybe first this question: is flexor working in scope 4.5?
Flexor is an extension of the Modular, so you open a Modular Window and place the Flexor modules from it's respective menu on the Modular surface.
It's correct that you almost miss it's presence.
I dunno how it is packed today, but you should also install (you might need to download them separately) the patches and examples.
When you unpack that stuff be sure to have 'include directories' active - then it should run without problems.
<font size=-1>[ This Message was edited by: astroman on 2005-12-21 17:26 ]</font>
alfonso
Post by alfonso »
Sure it works.
It will ask for the keys as you drop a FleXor module inside a modular frame or as you load a modular patch that contains FleXor modules.
They should be located in the Menu's that you find directly in the modular frame top, where all the other modules can be found.
djmicron
Post by djmicron »
i think you must download the flexor package from the adern page and put it manually in your scope folder......
vipal
Post by vipal »
thank u guys. gonna try what you advised me
vipal
Post by vipal »
well this is what assaf from adern wrote me:
flexor is not a device so it will not appear in your router window.
it is a set of modular modules, and needs modular 2 or modular 3 to work. (it can work on modular 1 but not recommended).
you need to either drag ready made patches from our patch collection (downloadable in our site)or just drag an empty modular and start patching with flexor modules.
