lossing my parametriq equalizer 4p
vipal
Post by vipal »
i can see my para equa. but its not working its like a dsp-file is missing. its very strange happened after i just re-installed scope.
i have the key for this instrument
the error message is:
cant find dsp file parametric equalizer 4p please check installation
but how? any help is very welcome. i have the same with e-reflector
samplaire
Post by samplaire »
Have you tried to search the installation folder for the file? What's the exact name of the file?
Image Sir samplaire scopernicus
Haiku Fristajl (in Polish)
"Those are blind who don't use Scope" SSS
<font size=-1>[ This Message was edited by: samplaire on 2005-12-14 07:28 ]</font>
vipal
Post by vipal »
well it says what i mentioned before
yes and i guess its not in the installation folder but what to do?
samplaire
Post by samplaire »
:sad:
vipal
Post by vipal »
i am a bit confused now. thanx on forehand to everybody who can help me.
in my routing window, under effects there is grapheq (stereo and mono as well). its in light blue while the other effects in the effects-pull-down-window are yellow.
when i activate grapheq there is this call:
cant find dsp file parametricequalizer 4p.
also grapheq is not working.
in the manual i can see that grapheq is not mentioned under effects but under studio. the grapheq.dev files are in the stereo and mono effects folder.
any hints for solving my problem?
the file is on the install disk under app/dsp. i believe it's just called "eq4p.dsp" it should be in the same place on your computer. if it's not, drag and drop it where it goes(when scope is closed, of course). if it is there, right click, choose "properties" and be sure it is not checked "write only".
samplaire
Post by samplaire »
...or try to install the grapheq once more from the oxe file you find here as 31_band_EQ_v2
samplaire
Post by samplaire »
I made an experiment. I removed a file called EQ4P.DSP from the dsp menu and got the same message you got trying to load the GraphEQ. So, this is the file you need. It can be found in the 4.5 install folder in DSP subfolder. So Gary is right :cool:
<font size=-1>[ This Message was edited by: samplaire on 2005-12-16 02:24 ]</font>
Nestor
Post by Nestor »
Also, when a device asks you to "reinstall", is not refering to SCOPE software as a whole, but the the device itself. When you get problems with devices, you will rarely need to install SCOPE anew, but just a little file, like in this case.
djmicron
Post by djmicron »
try to copy the dsp folder manually from the installation folder......
vipal
Post by vipal »
its true. when i dragged the file it went wrong, copy and past works perfectly. thanks.
Kymeia
Post by Kymeia »
I keep reading about this grapheq but when I try and install it it asks for a keyfile? I can't see where you would buy it though?
samplaire
Post by samplaire »
One you could buy it as a separate plug but now it's a part of the 4.5 upgrade.
Kymeia
Post by Kymeia »
Thats what I thought but I've have installed the upgrade key and its still asking for one.
vipal
Post by vipal »
i recently bought scope 4.0 in my s&s pack grapheq is seperate device with activation key.
vipal
Post by vipal »
samplaire
Post by samplaire »
Kymeia,
Have you tried to enter the key manually (you can find it in your 'my page' @creamware?
<font size=-1>[ This Message was edited by: samplaire on 2005-12-18 18:02 ]</font>
Kymeia
Post by Kymeia »
No its not on there. I've emailed Creamware now.
