sometimes i have this strange problem.
no matter of the dsp load, when i load a scope sampler 2000p or 4000 for ex., scope shuts down. then i am forced to load scope platform again.
what is this?
scope shuts down when i load scope samplers
my pc seems more stable than ever and i have problems with sts samplers.
this is strange.
you know i remember when i was just playing trying different configurations with my pc and it was so easy to load any sampler, 2000, 3000, 4000, 5000. i could even load them all together. i am not sure if i tested them on 96khz but ok...
now i cannot load one. i manage to load a sampler once in every 10 to 15 attempts.
strange.
now that i am on standard pc. most onboard components disabled and no irq shares. please help..........
IRQ 0 System timer OK
IRQ 1 PC/AT Enhanced PS/2 Keyboard (101/102-Key) OK
IRQ 3 Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD OK
IRQ 4 Communications Port (COM1) OK
IRQ 5 RADEON X800 Series OK
IRQ 6 Standard floppy disk controller OK
IRQ 7 Intel(R) 82801EB SMBus Controller - 24D3 OK
IRQ 7 Realtek AC'97 Audio OK
IRQ 8 System CMOS/real time clock OK
IRQ 9 Intel(R) 82801EB USB Universal Host Controller - 24D7 OK
IRQ 10 Silicon Image SiI 3112 SATARaid Controller OK
IRQ 11 Creamware Pulsar2 OK
IRQ 11 Creamware Scope OK
IRQ 12 Microsoft PS/2 Port Mouse (IntelliPoint) OK
IRQ 13 Numeric data processor OK
IRQ 14 Primary IDE Channel OK
IRQ 15 Secondary IDE Channel OK
this is strange.
strange.
it is disabled. actually i use for music raid0 discs without internet and without ac97.
only creamware.
are you sure that you can load without problems your sts samplers?
can you please try and load one sampler and after unload it and load anotherone? and a third one.....
please inform me of your situation. thank you very much.
only creamware.
i fixed it!
well.... i made 3 clean xp installations.
now i work as follows
sillicon controller
1 hd 120 for internet and other testings
1 hd 300g for starage and projects destination
ichr5 controller
1 hd 34raptor for only creamware environment
1 hd 34raptor for other non musical applications.
and also 1 external disc
now with scope clean from other things i can load as many sts samplers i like, for ex. i tested loading all samplers together and some twice and no problem.
now the only thing that i need is to make it more stable in 96khz.
ELVIS LIVES
<font size=-1>[ This Message was edited by: ARCADIOS on 2005-11-30 09:34 ]</font>
sillicon controller
ichr5 controller
ELVIS LIVES
You'll only get stability by kicking out the Scope Pro card, which has been reported to fail at 96kHz. I've been considering of doing just that for some occasions, but it would hurt to see the 15dsp card lying on the table and continuing to work with a only couple DSP - just as I needed them most at 96kHz
My PC had a memory change and upgrade recently, will report later when I've tried the STS series on this... Previously SFP frooze my PC when loading any STS or samples in it.
I'm sorry for the bad news on the Scope card, but it should save you some time troubleshooting
I didn't do any heavy work at 96khz, I just tried it a bit to see how did it sound, but apart the double resources used, I didn't notice any particular problem.On 2005-11-30 10:21, at0m wrote:
As I never had the slightest problem with sts's (at 44.1khz ,as I don't have other sample formats) might that instability be related to particular system problems?
